[petsc-dev] plans for preconditioners for SeqSELL
    Richard Tran Mills
    rtmills at anl.gov
    Tue Feb 13 17:51:11 CST 2018
Hi Stefano,
When using MATSELL for a PFLOTRAN simulation of a variably-saturated flow
problem (Richards equation) on a KNL box and running in MCDRAM, I see about
a 2X speedup in MatMult() vs. MATAIJ (using double-precision). This problem
has only one degree of freedom in each grid cell, and is using a
first-order finite volume spatial discretization, with a regular grid of
cuboid elements -- so the Jacobian basically has a 7-point stencil
structure. This is the sort of short row-length matrix for which I expect
MATSELL to do well.
If I run something like a reactive chemistry problem on the same grid with,
say, 12 primary chemical species -- so 12 degrees of freedom per grid cell
-- then MATSELL doesn't provide any benefit, and MATBAIJ is the thing to
use, as one would expect.
I haven't experimented very thoroughly with it (hmm... should probably do
such experiments), but I believe that, once matrix rows become sufficiently
long, then SELL doesn't provide an advantage over AIJ. This mattered more
for older vector processors that had much longer vector lengths (something
like 64 doubles) compared to the "long" vectors that KNL or Skylake server
has (8 doubles).
Best regards,
Richard
On Tue, Feb 13, 2018 at 3:40 AM, Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> Richard,
> what are the performances you get with MATSELL in PFLOTRAN?
> Today, I run the SELL matrix for the first time on a KNL with different
> problems (using PetIGA)  and got the results attached.
> It seems that SELL is faster then AIJ for 2D Poisson, and slightly faster
> for 3D Poisson. However, for multi-component problems (i.e. Elasticity
> and Cahn-Hilliard in mixed formulation) it has comparable performances or
> slower.
> in these cases AIJ is faster since it uses the inodes routines.
> Is this expected?
> These are the flags I used to compile PETSc on
> KNL --COPTFLAGS=-xMIC-AVX512 -O3 -mP2OPT_hpo_vec_remainder=F;
> 2018-02-12 21:04 GMT+03:00 Richard Tran Mills <rtmills at anl.gov>:
>> On Mon, Feb 12, 2018 at 8:47 AM, Smith, Barry F. <bsmith at mcs.anl.gov>
>> wrote:
>>> > On Feb 12, 2018, at 10:25 AM, Stefano Zampini <
>>> stefano.zampini at gmail.com> wrote:
>>> > Barry,
>>> > for sure Amat,Pmat is the right approach; however, with complicated
>>> user codes, we are not always in control of having a different Jacobian
>>> matrix.
>>> > Since Mat*SELL does not currently support any preconditioning except
>>> PCSOR and PCJACOBI, we ask the user to put codes like
>>> > if (type is SELL)
>>> >  create two matrices (and maybe modify the code in many other parts)
>>> > else
>>> >   ok with the previous code
>>>    I don't disagree with what you are saying and am not opposed to the
>>> proposed work.
>>>    Perhaps we need to do a better job with making the mat,pmat approach
>>> simpler or better documented so more people use it naturally in their
>>> applications.
>> I wrote some code like that in some of the Jacobian/function routines in
>> PFLOTRAN to experiment with MATSELL, and it works, but looks and feels
>> pretty hacky. And if I wanted to support it for all of the different
>> systems that PFLOTRAN can model, then I'd have to reproduce that it in many
>> different Jacobian and function evaluation routines. I also don't like that
>> it makes it awkward to play with the many combinations of matrix types and
>> preconditioners that PETSc allows: The above pseudocode should really say
>> "if (type is SELL) and (preconditioner is not PCSOR or PCJACOBI)". I do
>> think that Amat,Pmat is a good approach in many situations, but it's easy
>> to construct scenarios in which it falls short.
>> In some situations, what I'd like to have happen is what Stefano is
>> talking about, with an automatic conversion to AIJ happening if SELL
>> doesn't support an operation. But, ideally, I think this sort of implicit
>> format conversion shouldn't be something hard-coded into the workings of
>> SELL. Instead, there should be some general mechanism by which PETSc
>> recognizes that a particular operation is unsupported for a given matrix
>> format, and then it can (optionally) copy/convert to a different matrix
>> type (probably default to AIJ, but it shouldn't have to be AIJ) that
>> supports the operation. This sort of implicit data rearrangement game may
>> actually become more important if future computer architectures strongly
>> prefer different data layouts different types of operations (though let's
>> not get ahead of ourselves).
>> --Richard
>>>     Barry
>>> > Just my two cents.
>>> > 2018-02-12 19:10 GMT+03:00 Smith, Barry F. <bsmith at mcs.anl.gov>:
>>> > > On Feb 12, 2018, at 9:59 AM, Stefano Zampini <
>>> > > FYI, I just checked and MatSOR_*SELL does not use any vectorized
>>> instruction.
>>> > > Why just not converting to SeqAIJ, factor and then use the AIJ
>>> implementation for MatSolve for the moment?
>>> >   Why not use the mat, pmat feature of the solvers to pass in both
>>> matrices and have the solvers handle using two formats simultaneously
>>> instead of burdening the MatSELL code with tons of special code for
>>> automatically converting to AIJ for solvers etc?
>>> > > 2018-02-12 18:06 GMT+03:00 Stefano Zampini <
>>> stefano.zampini at gmail.com>:
>>> > > 2018-02-12 17:36 GMT+03:00 Jed Brown <jed at jedbrown.org>:
>>> > > Karl Rupp <rupp at iue.tuwien.ac.at> writes:
>>> > > > Hi Stefano,
>>> > > >> Is there any plan to write code for native ILU/ICC etc for
>>> SeqSELL, at least to have BJACOBI in parallel?
>>> > > > (imho) ILU/ICC is a pain to do with SeqSELL. Point-Jacobi should be
>>> > > > possible, yes. SELL is really just tailored to MatMults and a pain
>>> for
>>> > > > anything that is not very similar to a MatMult...
>>> > > There is already MatSOR_*SELL.  MatSolve_SeqSELL wouldn't be any
>>> harder.
>>> > > I think it would be acceptable to convert to SeqAIJ, factor, and
>>> convert
>>> > > the factors back to SELL.
>>> > > Yes, this was my idea. Today I have started coding something. I'll
>>> push the branch whenever I have anything working
>>> > > Stefano
>>> > > Stefano
>>> > Stefano
> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180213/63eced97/attachment.html>
