[petsc-dev] how come rank is an MPInt?
Smith, Barry F.
bsmith at mcs.anl.gov
Tue Feb 13 13:41:50 CST 2018
PetscLayOutFindOwner and PetscLayoutFindOwnerIndex() also have this perversity of using the wrong type. But I guess once we let the standards slip once we might as well willy nilly mix mix two different types as one anywhere.
> On Feb 13, 2018, at 12:10 PM, Jed Brown <jed at jedbrown.org> wrote:
> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>> typedef struct {
>> PetscInt rank; /* Rank of owner */
>> PetscInt index; /* Index of node on rank */
>> } PetscSFNode;
>> Shouldn't rank be a PetscMPIInt? and its various uses be fixed?
> The intent at some point was for this to be addressable from Fortran77
> as a single array. PetscInt is always large enough to hold an MPI int.
> We have the type in Fortran now, but is there a guarantee that alignment
> matches C alignment? If so, we could switch.
