[petsc-dev] plans for preconditioners for SeqSELL
    Richard Tran Mills
    rtmills at anl.gov
    Mon Feb 12 12:04:17 CST 2018
On Mon, Feb 12, 2018 at 8:47 AM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> > On Feb 12, 2018, at 10:25 AM, Stefano Zampini <stefano.zampini at gmail.com>
> wrote:
> > Barry,
> > for sure Amat,Pmat is the right approach; however, with complicated user
> codes, we are not always in control of having a different Jacobian matrix.
> > Since Mat*SELL does not currently support any preconditioning except
> PCSOR and PCJACOBI, we ask the user to put codes like
> > if (type is SELL)
> >  create two matrices (and maybe modify the code in many other parts)
> > else
> >   ok with the previous code
>    I don't disagree with what you are saying and am not opposed to the
> proposed work.
>    Perhaps we need to do a better job with making the mat,pmat approach
> simpler or better documented so more people use it naturally in their
> applications.
I wrote some code like that in some of the Jacobian/function routines in
PFLOTRAN to experiment with MATSELL, and it works, but looks and feels
pretty hacky. And if I wanted to support it for all of the different
systems that PFLOTRAN can model, then I'd have to reproduce that it in many
different Jacobian and function evaluation routines. I also don't like that
it makes it awkward to play with the many combinations of matrix types and
preconditioners that PETSc allows: The above pseudocode should really say
"if (type is SELL) and (preconditioner is not PCSOR or PCJACOBI)". I do
think that Amat,Pmat is a good approach in many situations, but it's easy
to construct scenarios in which it falls short.
In some situations, what I'd like to have happen is what Stefano is talking
about, with an automatic conversion to AIJ happening if SELL doesn't
support an operation. But, ideally, I think this sort of implicit format
conversion shouldn't be something hard-coded into the workings of SELL.
Instead, there should be some general mechanism by which PETSc recognizes
that a particular operation is unsupported for a given matrix format, and
then it can (optionally) copy/convert to a different matrix type (probably
default to AIJ, but it shouldn't have to be AIJ) that supports the
operation. This sort of implicit data rearrangement game may actually
become more important if future computer architectures strongly prefer
different data layouts different types of operations (though let's not get
ahead of ourselves).
--Richard
>     Barry
> > Just my two cents.
> > 2018-02-12 19:10 GMT+03:00 Smith, Barry F. <bsmith at mcs.anl.gov>:
> > > On Feb 12, 2018, at 9:59 AM, Stefano Zampini <
> stefano.zampini at gmail.com> wrote:
> > > FYI, I just checked and MatSOR_*SELL does not use any vectorized
> instruction.
> > > Why just not converting to SeqAIJ, factor and then use the AIJ
> implementation for MatSolve for the moment?
> >   Why not use the mat, pmat feature of the solvers to pass in both
> matrices and have the solvers handle using two formats simultaneously
> instead of burdening the MatSELL code with tons of special code for
> automatically converting to AIJ for solvers etc?
> > > 2018-02-12 18:06 GMT+03:00 Stefano Zampini <stefano.zampini at gmail.com
> > > 2018-02-12 17:36 GMT+03:00 Jed Brown <jed at jedbrown.org>:
> > > Karl Rupp <rupp at iue.tuwien.ac.at> writes:
> > > > Hi Stefano,
> > > >> Is there any plan to write code for native ILU/ICC etc for SeqSELL,
> at least to have BJACOBI in parallel?
> > > > (imho) ILU/ICC is a pain to do with SeqSELL. Point-Jacobi should be
> > > > possible, yes. SELL is really just tailored to MatMults and a pain
> for
> > > > anything that is not very similar to a MatMult...
> > > There is already MatSOR_*SELL.  MatSolve_SeqSELL wouldn't be any
> harder.
> > > I think it would be acceptable to convert to SeqAIJ, factor, and
> convert
> > > the factors back to SELL.
> > > Yes, this was my idea. Today I have started coding something. I'll
> push the branch whenever I have anything working
> > > Stefano
> > > Stefano
> > Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180212/460d3239/attachment.html>
