[petsc-dev] petsc/master: unable to link in C++ with last night PETSC_WITH_EXTERNAL_LIB variable changes
Sat Feb 10 19:03:30 CST 2018
On Sat, Feb 10, 2018 at 2:34 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> >> Note that PETSc's own dependency management is messy because someone in
> >> the early days of BuildSystem thought that concatenating strings was
> >> sufficient, instead of maintaining a structured dependency graph to be
> >> topologically sorted at the final stage (pkg-config does this).
> > Of course, we do have a structured dependency graph. Where is it not
> being
> > used?
> If the DAG structure was preserved, toStringNoDupes would never need to
> work with a list containing duplicate flags, including libraries like
> -ldl and -lm, because the topological sort would never have created
> duplicates in the first place.
If we were in charge of all dependencies, that would be true. However,
packages can
dump in things that need to link with. if we could require that all
dependencies be
specified through our system, then we could topologically sort and put out
all the
link libs. This is exactly what we do for configure tests already.
   Matt
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180210/b859d3ca/attachment-0001.html>
