[petsc-dev] petsc/master: unable to link in C++ with last night PETSC_WITH_EXTERNAL_LIB variable changes
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Sat Feb 10 14:27:10 CST 2018
  Eric,
    Ok thanks for the update, and for not requiring us to undo recent "improvements" to our handling of compiler libraries.
   Barry
> On Feb 10, 2018, at 2:25 PM, Éric Chamberland <Eric.Chamberland at giref.ulaval.ca> wrote:
> ok, let put our in-house code away, simply try this simple example:
> #include <mpi.h>
> int main() {
> /*empty!! let's see the .o */
> return 1;
> then:
> g++ -c test.cc -I/opt/openmpi-1.10.2/include -o test.o
> nm -C test.o | grep "MPI::" | grep " U "
>                  U MPI::Win::Free()
>                  U MPI::Comm::Comm()
>                  U MPI::Datatype::Free()
> so: as soon you are compiling a c++ file with this openmpi 1.10.2 (even if you use gcc -c test.cc -I/opt/openmpi-1.10.2/include -o test.o in my example) it *requires* you to link with mpi_cxx lib...
> That's the "problem", that's *my* fault to have relied on a PETSC variable to link with an mpi c++ lib....
> So I will add the mpi_cxx lib to our makefiles for these older versions of mpi...
> Sorry for the annoyance...
> But, as usual, thanks for your fast responses guys, you all deserve a gold medal!!! :)
> Eric
> Le 18-02-10 à 14:37, Jed Brown a écrit :
>> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>>>    Then the testing is more involved, need to first check if C++ bindings exist and then check if supplied automatically by compilers (like on Cray). Annoying, I'd prefer to avoid but I still don't have the definitive word if C++ bindings are the issue from Eric.
>> The undefined symbols are C++ bindings and they are referenced from a
>> source file named StatistiqueMemoire.* which is not part of PETSc or a
>> PETSc dependency.  We don't reference them so we shouldn't try to link
>> them.
