[petsc-dev] WHO BROKE THE TRIANGLE BUILD
    Matthew Knepley
    knepley at gmail.com
    Wed Feb  7 10:43:03 CST 2018
On Thu, Feb 8, 2018 at 3:06 AM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Thu, Feb 8, 2018 at 2:02 AM, Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> >>   That is yesterday's build. Today's next look ok.
> >>    I had accidentally made PETSc use std99 compiler for everything
> include
> >> external libraries
> >>    Do you have problems with the most recent branches right now?
> > Pulling and checking. I has not pulled from yesterday.
> > Does that mean Triangle is broken for stdc99? One more thing to fix.
> It needs to include <stdlib.h> and the build either needs to set
> -DNO_TIMER or the "struct timezone tz" needs to be deleted and
> gettimeofday() calls should take NULL as the second argument.
> I don't see a repository in which to make the change.
Yo uare right. We need to move Triangle to a pkg-triangle Git repo. I think
the only
thing that exists now is the tarball.
   Matt
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180208/fe0a2406/attachment.html>
