[petsc-dev] ARG_MAX and linking
Jed Brown
jed at jedbrown.org
Tue Feb 6 16:30:33 CST 2018
If it's the error I'm guessing you have, then we just need petsc_EXPORTS
to be defined when building the library. The current logic, I think,
only does that for the MS compiler.
Pierre Jolivet <pierre.jolivet at enseeiht.fr> writes:
> I tried to comment out the lines you pointed out, but the builds error out.
> Was I supposed to do something else?
>> On 6 Feb 2018, at 3:47 PM, Jed Brown <jed at jedbrown.org> wrote:
>> If it's a __declspec(dllexport) issue, it's probably just not being
>> handled correctly in petscsys.h. Actually, it could be this junk which
>> much be obsolete because we don't use CMake to build PETSc and also
>> don't define petsc_EXPORTS.
>> include/petscsys.h-#if defined(petsc_EXPORTS) /* CMake defines this when building the shared library */
>> include/petscsys.h:# define PETSC_VISIBILITY_PUBLIC PETSC_DLLEXPORT
>> include/petscsys.h-#else /* Win32 users need this to import symbols from petsc.dll */
>> include/petscsys.h-# define PETSC_VISIBILITY_PUBLIC PETSC_DLLIMPORT
>> include/petscsys.h-#endif
>>> I’m on master.
>>> Thanks, I think this is the way to go, though I’m now seeing a lot of undefined references, like there http://mingw-users.1079350.n2.nabble.com/imp-prefixes-when-linking-td7386007.html <http://mingw-users.1079350.n2.nabble.com/imp-prefixes-when-linking-td7386007.html>
>>>> On 6 Feb 2018, at 2:05 PM, Jed Brown <jed at jedbrown.org> wrote:
>>>> What branch are you on? I wonder if this is exacerbated by Scott's
>>>> "absolute path". You can configure --with-single-library=0 which will
>>>> link a separate libpetscsys, libpetscvec, etc.
>>>> There are Cygwin recipes in gmakefile that create argument files that
>>>> the linker reads as @args. We could use $(file > args, $^) to write
>>>> them with arbitrarily long command lines.
>>>>> Hello,
>>>>> I’m trying to compile PETSc with msys2 and MS MPI.
>>>>> Everything works out almost flawlessly, except when linking. Indeed, you generate a nice line of
>>>>> $ wc /tmp/cl
>>>>> 2 1234 69041 /tmp/cl
>>>>> 69041 characters, but
>>>>> $ getconf.exe ARG_MAX
>>>>> 32000
>>>>> Thus, sadly, the make fails with the following error
>>>>> /usr/bin/sh: /mingw64/bin/gcc: Argument list too long
>>>>> Do you know of a work around? Anyway to link the full library as multiple smaller libraries (I think you did that for some version X.Y with X << 3, didn’t you?)?
>>>>> Thanks,
>>>>> Pierre
