[petsc-dev] horrible lies about PETSc that need to be fixed
Smith, Barry F.
bsmith at mcs.anl.gov
Sun Feb 4 22:43:48 CST 2018
> On Feb 4, 2018, at 10:37 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
> On Sun, Feb 4, 2018 at 7:13 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> How dare you defame us in such a way. PETSc never ever "needed" cmake and certainly never will
> This is because we build PETSc with Metis and Parmetis (by default) that requires CMake. We usually need Metis/Parmetis for partitioning an unstructured mesh.
Sure but that does not mean that PETSc needs CMake, see the better wording
• CMake. A modern version of CMake (>2.8) is required to build some of the meta packages we need to include in PETSc.
http://mooseframework.com/wiki/ClusterInstructions/ClusterSetupSingleUser/
Probably a lot of text for the various cases could be combined to a single case, resulting in less text to maintain.
> http://mooseframework.org/wiki/BasicManualInstallation/OSX/#0-pre-reqs
> http://mooseframework.org/wiki/BasicManualInstallation/Linux/
> 0. Pre-Reqs
> • CMake. CMake is required to build PETSc.
> We could say CMake is required to build Metis/Parmetis?
> Fande,
