[petsc-dev] Faulty logic in MatHYPRESetPreallocation?
    Stefano Zampini
    stefano.zampini at gmail.com
    Sat Dec 29 03:13:41 CST 2018
Barry,
Probably this is an oversight from me. When I coded the MATHYPRE class, I
did not make much attention to the preallocation. Also, hypre did not seem
very robust to matrix reusage at the time. Take a look at the comments at
line 85 in ex115 from mat tests. Probably Pierre's fix will curate that
problem too.
Stefano
Il giorno Sab 22 Dic 2018, 06:30 Smith, Barry F. <bsmith at mcs.anl.gov> ha
scritto:
>    Stefeno,
>     Doe this look right to you?
>     Thanks
>     Barry
> > On Dec 17, 2018, at 3:18 AM, Pierre Jolivet via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
> > Hello,
> > I am not sure the hypre routines are called in the right order in
> MatHYPRESetPreallocation.
> > Indeed, attached, you’ll find two Massif logs, one with the current
> order (massif.out.bad), and the other (massif.out.better) with the attached
> patch applied.
> > In the former, you can see at the snapshot #31 that there is a call to
> hypre_CTAlloc in hypre_AuxParCSRMatrixInitialize (aux_parcsr_matrix.c:163).
> > This means that hypre is allocating memory as if it was not aware of the
> number of nonzero per row, even though I supply in my application the two
> arrays dnnz and onnz.
> > Am I missing something?
> > Thanks,
> > Pierre
> > <massif.out.bad><massif.out.better><patch-hypre.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181229/1fcbdfc7/attachment.html>
