[petsc-dev] Checkpoint-restart with DMPlex objects
    Matthew Knepley
    knepley at gmail.com
    Tue Dec 18 07:28:44 CST 2018
On Tue, Dec 18, 2018 at 6:54 AM Hapla Vaclav <vaclav.hapla at erdw.ethz.ch>
wrote:
> On 17 Dec 2018, at 20:36, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Dec 17, 2018 at 12:11 PM Lawrence Mitchell <wence at gmx.li> wrote:
>> > On 17 Dec 2018, at 11:56, Hapla Vaclav <vaclav.hapla at erdw.ethz.ch>
>> wrote:
>> > Matt, great that your reminded this email. I actually completely missed
>> it that time.
>> >> On 14 Dec 2018, at 19:54, Matthew Knepley via petsc-dev <
>> petsc-dev at mcs.anl.gov> wrote:
>> >> I would like:
>> >> - To be able to dump the DMPlex, and fields, on N processes
>> >> I think the current HDF5 does what you want.
>> >> - To be able to load the DMPlex, and fields, on P processes.  In the
>> first instance, to get things going, I am happy if P=1.
>> >> I think this also works with arbitrary P, although the testing can be
>> described as extremely thin.
>> > I think we need to be much more precise here. First off, there are now
>> two HDF5 formats:
>> > 1) PETSC_VIEWER_HDF5_PETSC - store Plex graph serialization
>> > 2) PETSC_VIEWER_HDF5_XDMF - store XDMF-compatible representation of
>> vertices and cells
>> > 3) PETSC_VIEWER_HDF5_VIZ slightly extends 2) with some stuff for
>> visualization, you perhaps understand it better
>> > PETSC_VIEWER_DEFAULT/PETSC_VIEWER_NATIVE mean store all three above. I
>> think what Lawrence calls Native should be 1).
>> > The format 1) is currently written in parallel but loaded sequentially
>> https://bitbucket.org/petsc/petsc/src/fbb1886742ac2bbe3b4d1df09bff9724d3fee060/src/dm/impls/plex/plexhdf5.c#lines-834
>> > I don't understand, how it can work correctly for a distributed mesh
>> while the Point SF (connecting partitions) is not stored FWICS. I think
>> there's even no PetscSFView_HDF5(). I will check it more deeply soon.
>> > The format 2) is for which I implemented parallel DMLoad().
>> > Unfortunately, I can't declare it bulletproof until we declare parallel
>> DMPlexInterpolate() as 100% working. I did quite some work towards it in
>> https://bitbucket.org/petsc/petsc/pull-requests/1227/dmplexintepolate-fix-orientation-of-faces/
>> > but as stated in the PR summary, there are still some examples failing
>> because of the wrong Point SF which is partly fixed in
>> knepley/fix-plex-interpolate-sf but it seems it's not yet finished. Matt,
>> is there any chance you could look at it at some point in near future?
>> > I think for Lawrence's purposes, 2) can be used to read the initial
>> mesh file but for checkpointing 1) seems to be better ATM because it dumps
>> everything including interpolated edges & faces, labels and perhaps some
>> more additional information.
>> OK, so I guess there are two different things going on here:
>> 1. Store the data you need to reconstruct a DMPlex
>> 2. Store the data you need to have a DMPlex viewable via XDMF.
>> 3. Store the data you need to reconstruct a DMPlex AND have it viewable
>> via XDMF.
>> For checkpointing only purposes, I only really need 1; for viz purposes,
>> one only needs 2; ideally, one would not separate viz and checkpointing
>> files if there is sufficient overlap of data (I think there is), which
>> needs 3.
>> > I will nevertheless keep on working to improve 2) so that it can store
>> edges & faces & labels in the XDMF-compatible way.
>> >> For dumping, I think I can do DMView(dm) in PETSc "native" format, and
>> that will write out the topology in a global numbering.
>> >> I would use HDF5.
>> >> For the field coefficients, I can just VecView(vec).  But there does
>> not appear to be any way of saving the Section so that I can actually
>> attach those coefficients to points in the mesh.
>> >> Hmm, I will check this right now. If it does not exist, I will write
>> it.
>> > No, it certainly doesn't exist. There is only ASCII view implemented.
>> >> I can do PetscSectionCreateGlobalSection(section), so that I have a
>> the global numbering for offsets, but presumably for the point numbering, I
>> need to convert the local chart into global point numbers using
>> DMPlexCreatePointNumbering?
>> >> No, all Sections use local points. We do not use global point numbers
>> anywhere in Plex.
>> > True. DMPlex is partition-wise sequential. The only thing which
>> connects the submeshes is the Point SF.
>> OK, so I think I misunderstood what the dump format looks like then. For
>> parallel store/load cycle when I go from N to P processes what must I do?
>> If I understand correctly the dump on N processes contains:
>> For each process, in process-local numbering
>>  - The DMPlex topology on that process
>> Now, given that the only thing that connects these local pieces of the DM
>> together is the point SF, as Vaclav says, it must be the case that a
>> reloadable dump file contains that information.
> No, the dump contains a completely consistent serial DM. Now I remember
> why parallel load is not implemented :)
> We demand that the dump look identical from any number of procs for all
> PETSc stuff. Thus we get a global renumbering
> and dump with that for all things.
> Oh I see. I misunderstood this. More clear to me know -
> DMPlexCreatePointNumbering() is employed in DMPlexView_HDF5_Internal().
> Now, when we load in parallel, we need to use the new parallel loading
> from Michael.
> What exactly do you mean?
> If I remember well Michael implemented a parallel MED loader and it uses DMPlexCreateFromCellListParallel()
> just as my XDMF-HDF5 reader does.
> Is this function what you mean by "the new parallel loading"?
Yes exactly. You are doing it right. We just need to extend that. Actually,
I think we should probably just store an attribute for interpolated meshes,
and interpolate on load. This is much simpler, less storage, and makes
everything uniform. What do you think?
    Matt
> Thanks
> Vaclav
> I have not yet written that, but it should
> be straightforward :) So the below is not really right. We need to call
> parallel load for the topology. Then we need code that
> loads the labels and uses the migration SF to redistribute them, but I
> think that code already exists for redistribution, so we
> just hijack it.
>   Matt
>> OK, so to dump a field so that we can reload it we must need:
>> - topology (in local numbering)
>> - point SF (connecting the local pieces of the topology together)
>> - Vector (dofs), presumably in local layout to make things easier
>> - Section describing the vector layout (local numbering)
>> So to load, I do:
>> 1. load and distribute topology, and construct new point SF (this
>> presumably gives me a "migration SF" that maps from old points to new points
>> 2. Broadcast the Section over migration SF so that we know how many dofs
>> belong to each point in the new topology
>> 3. Broadcast the Vec over the migration SF to get the dofs to the right
>> place.
>> Whenever I think of this on paper it seems "easy", but then I
>> occasionally try and sit down and do it and immediately get lost, so I am
>> normally missing something.
>> What am I missing this time?
>> Lawrence
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181218/205f44d2/attachment-0001.html>
