[petsc-dev] need for HDF5 < 1.8.0 support?
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Fri Dec  7 16:49:10 CST 2018
 As I said, I'm convinced, I'm fine with removing the old code
   Barry
> On Dec 7, 2018, at 2:47 PM, Jed Brown <jed at jedbrown.org> wrote:
> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>>>>>> A potential drawback is some users also use HDF5 directly in their code and may be using an older version (people are very slow to change).
>>>>> The HDF5 developers were very deliberate about this.  You can still use
>>>>> the old API in your own code while linking to the new library.  See
>>>>> H5_USE_16_API.
>>>>> https://support.hdfgroup.org/HDF5/doc/RM/APICompatMacros.html
>>>>  This pages is a firehose. Most people who have HDF5 in their code (that someone else probably wrote) will never get through this page to know what to do.
>>> You literally just compile that old code using -DH5_USE_16_API while using new HDF5 libraries and headers.
>>  Where do you put this -DH5_USE_16_API thing? I literally don't have a clue how my build system works. I would rather just stick to the old version since its worked for the last n years. (This is the average user/developer of package/application A)
> I get your point, but instructions are simple and we can't stay in the
> dark ages forever.  I think the HDF5 folks did a good job with their API
> deprecations.  We'd be upset if people were going through pains to
> support petsc-2.2.
> ./configure CPPFLAGS=-DH5_USE_16_API
