[petsc-dev] need for HDF5 < 1.8.0 support?
Smith, Barry F.
bsmith at mcs.anl.gov
Fri Dec 7 14:32:29 CST 2018
> On Dec 7, 2018, at 2:25 PM, Jed Brown <jed at jedbrown.org> wrote:
> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>>>> A potential drawback is some users also use HDF5 directly in their code and may be using an older version (people are very slow to change).
>>> The HDF5 developers were very deliberate about this. You can still use
>>> the old API in your own code while linking to the new library. See
>>> H5_USE_16_API.
>>> https://support.hdfgroup.org/HDF5/doc/RM/APICompatMacros.html
>> This pages is a firehose. Most people who have HDF5 in their code (that someone else probably wrote) will never get through this page to know what to do.
> You literally just compile that old code using -DH5_USE_16_API while using new HDF5 libraries and headers.
Where do you put this -DH5_USE_16_API thing? I literally don't have a clue how my build system works. I would rather just stick to the old version since its worked for the last n years. (This is the average user/developer of package/application A)
>> I'm fine with removing the older versions if everyone else is but I definitely remember this exact issue occurring in the past; perhaps now HDF5 has resolved it somewhere in their firehose.
>> Barry
