[petsc-dev] need for HDF5 < 1.8.0 support?
    Jed Brown
    jed at jedbrown.org
    Fri Dec  7 08:48:47 CST 2018
I'm in favor of requiring >=1.8.0.
Hapla Vaclav via petsc-dev <petsc-dev at mcs.anl.gov> writes:
> I wanted to add support for HDF5 attributes of groups (currently only datasets).
> But I already feel like held back by supporting HDF5 older than 1.8.0. Do we still need that?
> My arguments to get rid of that support:
> 1) It seems we already use some 1.8.0+ functions anyway (might be my fault, though).
> 2) We could get rid of all those #if
> 3) There were quite some useful API functions introduced in that release which would make the code simpler. For instance, H5O* functions allow handling groups and datasets the same way.
> Ad 2,3 consider this
> /* OLD */
> #if (H5_VERS_MAJOR * 10000 + H5_VERS_MINOR * 100 + H5_VERS_RELEASE >= 10800)
>   if (dataset) {
>     PetscStackCallHDF5Return(object, H5Dopen2, (h5, parent, H5P_DEFAULT));
>   } else if (type == H5O_TYPE_GROUP) {
>     PetscStackCallHDF5Return(object, H5Gopen2, (h5, parent, H5P_DEFAULT));
> #else
>   if (dataset) {
>     PetscStackCallHDF5Return(object, H5Dopen, (h5, parent));
>     PetscStackCallHDF5Return(object, H5Gopen, (h5, parent));
> #endif
>   if (dataset) {
>     PetscStackCallHDF5Return(err, H5Dclose, (object));
>     PetscStackCallHDF5Return(err, H5Gclose, (object));
> /* NEW */
>   PetscStackCallHDF5Return(object, H5Oopen, (h5, parent, H5P_DEFAULT));
>   PetscStackCallHDF5Return(err, H5Oclose, (object));
> Additionally, function H5Oget_info() which can say whether the object is group or dataset was also introduced only in 1.8.0. So the dataset flag above would have to be set by a user it seems...
> So I personally think it's already about time to leave the old HDF5 API behind... Objections? If no, I would make a PR which would clean the code from the #ifs and forbid the older versions already in configure.
> Vaclav
