[petsc-dev] need for HDF5 < 1.8.0 support?
Hapla Vaclav
vaclav.hapla at erdw.ethz.ch
Fri Dec 7 03:35:15 CST 2018
I wanted to add support for HDF5 attributes of groups (currently only datasets).
But I already feel like held back by supporting HDF5 older than 1.8.0. Do we still need that?
My arguments to get rid of that support:
1) It seems we already use some 1.8.0+ functions anyway (might be my fault, though).
2) We could get rid of all those #if
3) There were quite some useful API functions introduced in that release which would make the code simpler. For instance, H5O* functions allow handling groups and datasets the same way.
Ad 2,3 consider this
/* OLD */
#if (H5_VERS_MAJOR * 10000 + H5_VERS_MINOR * 100 + H5_VERS_RELEASE >= 10800)
if (dataset) {
PetscStackCallHDF5Return(object, H5Dopen2, (h5, parent, H5P_DEFAULT));
} else if (type == H5O_TYPE_GROUP) {
PetscStackCallHDF5Return(object, H5Gopen2, (h5, parent, H5P_DEFAULT));
#else
if (dataset) {
PetscStackCallHDF5Return(object, H5Dopen, (h5, parent));
PetscStackCallHDF5Return(object, H5Gopen, (h5, parent));
#endif
if (dataset) {
PetscStackCallHDF5Return(err, H5Dclose, (object));
PetscStackCallHDF5Return(err, H5Gclose, (object));
/* NEW */
PetscStackCallHDF5Return(object, H5Oopen, (h5, parent, H5P_DEFAULT));
PetscStackCallHDF5Return(err, H5Oclose, (object));
Additionally, function H5Oget_info() which can say whether the object is group or dataset was also introduced only in 1.8.0. So the dataset flag above would have to be set by a user it seems...
So I personally think it's already about time to leave the old HDF5 API behind... Objections? If no, I would make a PR which would clean the code from the #ifs and forbid the older versions already in configure.
Vaclav
