[petsc-dev] No rule to make target 'mfem-build'
Balay, Satish balay at mcs.anl.gov
Sun Dec 2 11:37:35 CST 2018
The following change gets rid of the warning on my linux box..
diff --git a/makefile b/makefile
index b16da461fb..38b92d50fd 100644
--- a/makefile
+++ b/makefile
@@ -241,7 +241,7 @@ distclean: chk_petscdir
 reconfigure:
-	@${PYTHON} ${PETSC_ARCH}/lib/petsc/conf/reconfigure-${PETSC_ARCH}.py
+	@unset MAKEFLAGS && ${PYTHON} ${PETSC_ARCH}/lib/petsc/conf/reconfigure-${PETSC_ARCH}.py
 install:
 	@${PYTHON} ./config/install.py -destDir=${DESTDIR}
Satish
On Sun, 2 Dec 2018, Lisandro Dalcin wrote:
> Maybe configure should not warn if environment variables are empty? Or at
> least special-case MAKEFLAGS such that `make reconfigure` does not print
> the confusing message? What do you think, Satish?
> On Sat, 1 Dec 2018 at 22:23, Hapla Vaclav via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
> > ... except that it somehow passes this MAKEFLAGS= to configure, resulting
> > in the confusing message ...
> > 1. 12. 2018 v 17:33, Stefano Zampini <stefano.zampini at gmail.com>:
> > Make reconfigure is equivalent to rerun the configure script
> > Il giorno Sab 1 Dic 2018, 18:09 Hapla Vaclav <vaclav.hapla at erdw.ethz.ch>
> > ha scritto:
> >> ... but this is apparently not caused by your merge.
> >> Is it just normal behavior of make reconfigure?
> >> I didn't know about this, I always call the reconfigure script directly.
> >> Vaclav
> >> > 1. 12. 2018 v 16:04, Hapla Vaclav <vaclav.hapla at erdw.ethz.ch>:
> >> > Thanks, you're right.
> >> > However,
> >> > $ make reconfigure
> >> >             Configuring PETSc to compile on your system
> >> >                          ***** WARNING: MAKEFLAGS (set to ) found in
> >> environment variables - ignoring
> >> >                        use ./configure MAKEFLAGS=$MAKEFLAGS if you
> >> really want to use that value ******
> >> > although I have no such variable set in my shell.
> >> > Vaclav
> >> >> 1. 12. 2018 v 15:36, Stefano Zampini <stefano.zampini at gmail.com>:
> >> >> I have added a new package that gets built after petsc. You have to
> >> run
> >> >> make reconfigure
> >> >> Il giorno Sab 1 Dic 2018, 16:52 Hapla Vaclav <
> >> vaclav.hapla at erdw.ethz.ch> ha scritto:
> >> >> Hi Stefano
> >> >> After pulling latest master, I get the following at the end of make
> >> output:
> >> >> make[1]: *** No rule to make target 'mfem-build', needed by
> >> 'all-gnumake-local'.  Stop.
> >> >> make[1]: Leaving directory '/scratch/petsc-dev-1'
> >> >> Now to check if the libraries are working do:
> >> >> make PETSC_DIR=/scratch/petsc-dev-1 PETSC_ARCH=arch-linux-gcc check
> >> >> Do you think you could remove that line for non-mfem builds? I think
> >> it looks like an error for a user.
> >> >> Vaclav
