[petsc-dev] Compiling PETsc against openblas on Linux
Antonio Trande
anto.trande at gmail.com
Fri Aug 31 12:16:22 CDT 2018
Hello everyone.
How to configure correctly PETsc compilation against OpenBLAS?
'openblas' libraries are
/usr/include/openblas/*
/usr/lib(64)/libopenblas.so
/usr/lib(64)/libopenblas.a
/usr/lib(64)/libopenblas64.so
If i use
--with-openblas=1 \
--with-openblas-include=%{_includedir} \
--with-openblas-lib=%{_libdir}/libopenblas.so \
--known-64-bit-blas-indices=0 \
Configure fails with
TEST configureLibrary from
config.packages.openblas(/home/sagitter/rpmbuild/BUILD/petsc-3.9.3/petsc-3.9.3/config/BuildSystem/config/packages/openblas.py:25)
TESTING: configureLibrary from
config.packages.openblas(config/BuildSystem/config/packages/openblas.py:25)
Checking for a functional openblas
Not checking for library in User specified OPENBLAS
libraries: [] because no functions given to check for
TEST check from
config.libraries(/home/sagitter/rpmbuild/BUILD/petsc-3.9.3/petsc-3.9.3/config/BuildSystem/config/libraries.py:155)
TESTING: check from
config.libraries(config/BuildSystem/config/libraries.py:155)
Checks that the library "libName" contains "funcs", and if it does
defines HAVE_LIB"libName"
- libDir may be a list of directories
- libName may be a list of library names
No functions to check for in library [] []
Checking for headers User specified OPENBLAS libraries: []
**** Configure header /tmp/petsc-y1LlML/confdefs.h ****
Antonio Trande
Fedora Project
mailto 'sagitter at fedoraproject dot org'
GPG key: 0x5E212EE1D35568BE
GPG key server: https://keys.fedoraproject.org/
