[petsc-dev] Undefined symbols for _kspfgmresmodifypcksp_ and _kspfgmresmodifypcnochange_ when rebuilding
    Patrick Sanan
    patrick.sanan at gmail.com
    Wed Aug 22 07:09:46 CDT 2018
Thanks all! "make allfortranstubs && make" is certainly practical enough
for me. I'd naively been assuming that "make deletefortranstubs && make"
would have the same effect.
2018-08-22 13:09 GMT+02:00 Jose E. Roman <jroman at dsic.upv.es>:
> > El 22 ago 2018, a las 12:52, Matthew Knepley <knepley at gmail.com>
> escribió:
> > On Wed, Aug 22, 2018 at 6:35 AM Lawrence Mitchell <lawrence at wence.uk>
> wrote:
> > > On 22 Aug 2018, at 10:04, Patrick Sanan <patrick.sanan at gmail.com>
> wrote:
> > > This happens fairly frequently when I try to switch/update branches of
> PETSc (here invoked by building my own code, but the error message looks
> the same with "make check"):
> > > $ make
> > > /Users/patrick/petsc-stagbl/arch-darwin-stagbl-double-extra-debug/bin/mpicc
> -o runme.o -c -Wall -Wwrite-strings -Wno-strict-aliasing
> -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g3
>  -I/Users/patrick/petsc-stagbl/include -I/Users/patrick/petsc-stagbl/
> arch-darwin-stagbl-double-extra-debug/include -I/opt/X11/include
> `pwd`/runme.c
> -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress
> -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-no_compact_unwind
> -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
> -fstack-protector -fvisibility=hidden -g3  -o runme runme.o
> -Wl,-rpath,/Users/patrick/petsc-stagbl/arch-darwin-stagbl-double-extra-debug/lib
> -L/Users/patrick/petsc-stagbl/arch-darwin-stagbl-double-extra-debug/lib
> -Wl,-rpath,/opt/X11/lib -L/opt/X11/lib -Wl,-rpath,/opt/local/lib/
> gcc7/gcc/x86_64-apple-darwin17/7.3.0 -L/opt/local/lib/gcc7/gcc/x86_64-apple-darwin17/7.3.0
> -Wl,-rpath,/opt/local/lib/gcc7 -L/opt/local/lib/gcc7 -lpetsc -lcmumps
> -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lumfpack
> -lklu -lcholmod -lbtf -lccolamd -lcolamd -lcamd -lamd -lsuitesparseconfig
> -lsuperlu_dist -lHYPRE -lsundials_cvode -lsundials_nvecserial
> -lsundials_nvecparallel -llapack -lblas -lparmetis -lmetis -lX11 -lyaml
> -lstdc++ -ldl -lmpifort -lmpi -lpmpi -lgfortran -lquadmath -lm -lstdc++ -ldl
> > > Undefined symbols for architecture x86_64:
> > >   "_kspfgmresmodifypcksp_", referenced from:
> > >       import-atom in libpetsc.dylib
> > >   "_kspfgmresmodifypcnochange_", referenced from:
> > > ld: symbol(s) not found for architecture x86_64
> > > collect2: error: ld returned 1 exit status
> > > I don't know why this is, exactly. Maybe it's more obvious from the
> perspective of someone more expert on the Fortran interface, and we could
> save some time reconfiguring (if these two symbols are really the only
> issue).
> > >  For these two symbols, the corresponding functions are declared but
> not defined in
> > >     src/ksp/ksp/impls/gmres/fgmres/ftn-custom/zmodpcff.c
> > > "make deletefortranstubs" by itself doesn't seem to solve the problem.
> My sledgehammer workaround is to do everything short of blowing away my
> entire $PETSC_ARCH directory:
> > >     make deletefortranstubs && make allclean && make reconfigure &&
> make && make check
> > Does it work to do:
> > In these cases?
> > Lawrence is correct. Here is what is happening.
> > Someone changes an interface, and you pull the change. The header
> changes will cause all the C files
> > using that API to rebuild. However, the doc system (sowing) runs bfort
> on the C file to generate the Fortran
> > binding. It runs on all headers at once, so there is no separately rule
> for bforting a C file when it changes.
> > Things are now even worse, since we have Python code separate from bfort
> which create the Fortran
> > modules, which also will not fire on updates to the C file.
> > The simplest fix is that you know that every time you see this problem,
> you rerun 'make allfortranstubs'.
> > The complicate fix is to rewrite bfort and the module generation into
> one program which respects the
> > dependency information. Since there is literally no credit associated
> with this job, it is unlikely ever to happen.
> > We await the passing of the last Fortran programmer.
> Another fix is to have a custom Fortran stub for KSPFGMRESModifyPCKSP()
> and KSPFGMRESModifyPCNoChange(), rather than an automatic Fortran stub.
> That is, change /*@ to /*@C and add a definition for these functions in
> zmodpcff.c
> Jose
> >    Matt
> > I used to have to do this, until eventually I gave up and built without
> the fortran interfaces (may not be an option).
> > I tried to unpick the make rules so that if you built with fortran
> interfaces, the generation of individual interface would depend on the
> relevant C files, but gave up, because I couldn't see what was going on.
> > Cheers,
> > Lawrence
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180822/e2ff01de/attachment.html>
