[petsc-dev] How to enforce private data/methods in PETSc?
Junchao Zhang
jczhang at mcs.anl.gov
Fri Aug 10 23:02:06 CDT 2018
See this example, after multiple casts, the code directly accesses
VecScatter_MPI_General's members, with an assumption that from->n is the
total number of receive processors. When I separate intranode / internode
communications, I have to maintain this assumption.
385: *PetscErrorCode
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscErrorCode.html#PetscErrorCode>
MatMatMultNumeric_MPIDense(Mat
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/Mat.html#Mat>
A,Mat <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/Mat.html#Mat>
B,Mat <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/Mat.html#Mat>
C)*386: {
389: Mat_MPIAIJ *aij = (Mat_MPIAIJ*) A->data;
393: VecScatter
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecScatter.html#VecScatter>
ctx = aij->Mvctx;394: VecScatter_MPI_General *from =
(VecScatter_MPI_General*) ctx->fromdata;395: VecScatter_MPI_General
*to = (VecScatter_MPI_General*) ctx->todata;
411: PetscMalloc4
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscMalloc4.html#PetscMalloc4>(B->cmap->N*from->starts[from->n],&contents->rvalues,412:
B->cmap->N*to->starts[to->n],&contents->svalues,413:
from->n,&contents->rwaits,414:
to->n,&contents->swaits);
--Junchao Zhang
On Fri, Aug 10, 2018 at 10:33 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Aug 10, 2018 at 11:29 PM Junchao Zhang <jczhang at mcs.anl.gov>
> wrote:
>> It seems we do not have naming conventions for private members.
> I am not sure I understand. There are no public members. For private
> functions, we do have
> a naming convention, but it is newly created, so many of the existing
> functions break the rules.
> Matt
>> --Junchao Zhang
>> On Fri, Aug 10, 2018 at 9:43 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Fri, Aug 10, 2018 at 5:43 PM Junchao Zhang <jczhang at mcs.anl.gov>
>>> wrote:
>>>> I met several bugs that remind me to raise this question. In PETSc,
>>>> object of type A can arbitrarily access object of type B's data. But
>>>> designer of B may later change the meaning of its data (and of course,
>>>> update B's interfaces, which are usually local to few files). The designer
>>>> may think the job is done, but actually it is not. He/she has to grep the
>>>> code to know where its data members are accessed (that is relatively easy
>>>> to get) and what is the contract, for example, is an array assumed to be
>>>> sorted (that is hard to know). With C++, one can use private to minimize
>>>> data exposure.
>>> This just has to be coding discipline. People should not be accessing
>>> private members.
>>> Matt
>>>> --Junchao Zhang
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180810/70bea7d7/attachment.html>
