[petsc-dev] How to enforce private data/methods in PETSc?
Matthew Knepley
knepley at gmail.com
Fri Aug 10 21:43:40 CDT 2018
On Fri, Aug 10, 2018 at 5:43 PM Junchao Zhang <jczhang at mcs.anl.gov> wrote:
> I met several bugs that remind me to raise this question. In PETSc,
> object of type A can arbitrarily access object of type B's data. But
> designer of B may later change the meaning of its data (and of course,
> update B's interfaces, which are usually local to few files). The designer
> may think the job is done, but actually it is not. He/she has to grep the
> code to know where its data members are accessed (that is relatively easy
> to get) and what is the contract, for example, is an array assumed to be
> sorted (that is hard to know). With C++, one can use private to minimize
> data exposure.
This just has to be coding discipline. People should not be accessing
private members.
Matt
> --Junchao Zhang
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180810/177f9b35/attachment.html>
