[petsc-dev] any script to extract data from "-log_view"?
    Matthew Knepley
    knepley at gmail.com
    Wed Aug  8 19:57:00 CDT 2018
On Wed, Aug 8, 2018 at 7:23 PM Fande Kong <fdkong.jd at gmail.com> wrote:
> Hi all,
> If we are going to do a scaling study, can we automatically make a plot
> based on a bunch of output files (from -log_view)? It is a big pain to
> manually copy data if we have a lot of output files.
I use
  -log_view :run1.py:ascii_info_detail
and then import run1.py. You probably want __import__ so that you can
import all the modules programmatically. I am doing exactly this to automate
scaling. Hopefully we can do it for you in a couple of weeks.
     Matt
> Fande,
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180808/00164a76/attachment.html>
