[petsc-dev] Error in MatGetDiagonal_Shell?
Matthew Knepley
knepley at gmail.com
Mon Apr 30 05:41:06 CDT 2018
On Mon, Apr 30, 2018 at 1:38 AM, Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> > On Apr 30, 2018, at 3:14 AM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> > I don't understand
> > The code has
> > ierr = MatGetDiagonal(A,W2);CHKERRQ(ierr);
> > ierr = VecView(W2,viewer);CHKERRQ(ierr);
> > the output from this VecView seems to match the diagonal of the matrix
> printed earlier.
> >> On Apr 29, 2018, at 10:02 AM, Stefano Zampini <
> stefano.zampini at gmail.com> wrote:
> >> By looking at src/mat/examples/tests/output/ex88_1.out, it seems that
> the output of MatGetDiagonal is wrong for MATSHELL.
> >> it should be
> >> 2.96782e+08
> >> 1.41731e+09
> >> and not (as computed)
> >> 1.10918e+08
> >> 2.06459e+08
> > What do you mean "as computed"? The output file does not contain
> >> 1.10918e+08
> >> 2.06459e+08
> > anywhere.
> > Are you modifying the example and running it again to get the
> incorrect value?
> Yes, my bad. I did not explain it correctly
> From maint, if you just run ex88 you will get the incorrect output, which
> is not caught in the nightlyies because floating point values are
> completely ignored.
Now that we ignore all values, tests need to be changed to check the
distance from the correct vector.
Matt
> [szampini at localhost tests]$ ./ex88
> Matrix of type: shell
> Mat Object: 1 MPI processes
> type: seqdense
> 2.9678190300000000e+08 3.9288008100000000e+08
> 6.1374683500000000e+08 1.4173141580000000e+09
> Vec Object: 1 MPI processes
> type: seq
> 3.92973e+19
> 8.54197e+19
> type: seq
> 1.10918e+08
> 2.06459e+08
> MatDiagonalSet not tested on MATSHELL
> > Barry
> >> Stefano
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180430/07b778b7/attachment.html>
