[petsc-dev] Error with --download-strumpack
    Junchao Zhang
    jczhang at mcs.anl.gov
    Tue Apr 24 12:33:33 CDT 2018
Great, thanks.
--Junchao Zhang
On Tue, Apr 24, 2018 at 11:54 AM, Balay, Satish <balay at mcs.anl.gov> wrote:
> Ok - for https://github.com/pghysels/STRUMPACK/archive/v2.2.0.tar.gz to
> work - you need:
> diff --git a/config/BuildSystem/config/packages/strumpack.py
> b/config/BuildSystem/config/packages/strumpack.py
> index e3d32666f0..0edd9c19e0 100644
> --- a/config/BuildSystem/config/packages/strumpack.py
> +++ b/config/BuildSystem/config/packages/strumpack.py
> @@ -6,6 +6,7 @@ class Configure(config.package.CMakePackage):
>      config.package.CMakePackage.__init__(self, framework)
>      self.gitcommit        = 'v2.1.0'
>      self.download         = ['git://https://github.com/pghysels/STRUMPACK
> ','http://portal.nersc.gov/project/sparse/strumpack/strumpack-2.1.0.tar.gz
> +    self.downloaddirnames = ['STRUMPACK','strumpack']
>      self.functions        = ['STRUMPACK_init']
>      self.includes         = ['StrumpackSparseSolver.h']
>      self.liblist          = [['libstrumpack.a']]
> Are you updating petsc-master to use v2.2.0 of strumpack?
> Satish
> On Tue, 24 Apr 2018, Satish Balay wrote:
> > You can use:
> > --download-strumpack=1 --download-strumpack-commit=v2.2.0
> > Currently the tarball URL used is
> > - and it uses the notation:
> > strumpack-2.1.0/
> > But https://github.com/pghysels/STRUMPACK/archive/v2.2.0.tar.gz would
> > be using a different notation for 'dirname' - so configure can't find
> > it.
> > Satish
> > On Tue, 24 Apr 2018, Junchao Zhang wrote:
> > > Hi, Satish,
> > >  This configure option --download-strumpack=
> > > https://github.com/pghysels/STRUMPACK/archive/v2.2.0.tar.gz does not
> work. It
> > > looks it is because the package uses upper case for its name.
> > >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
> for
> > > details):
> > > Error during download/extract/detection of STRUMPACK:
> > > Looking for STRUMPACK at git.strumpack, hg.strumpack or a directory
> > > starting with ['strumpack']
> > > --Junchao Zhang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180424/f89e6a68/attachment.html>
