[petsc-dev] PetscOptions defaults after PetscInitialize
Smith, Barry F.
bsmith at mcs.anl.gov
Sun Apr 22 19:54:11 CDT 2018
> On Apr 22, 2018, at 7:45 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Apr 22, 2018 at 8:41 PM, Jed Brown <jed at jedbrown.org> wrote:
> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
> > Yuck, I think a far better user API is that PetscOptionsInsertFile() be callable before PetscInitialize(). The problem is that people have shoveled so much post-PetscInitialize() code into PetscOptionsInsertFile() over the years that stripping it all out would be painful. Maybe get a simplier pre- 2005 version of the routine and strip out the post-PetscInitialize() material?
> You want every rank to open the file independently? Or
> PetscOptionsInsertFile somehow caches the file contents without using
> PetscMalloc and broadcasts it after reaching PetscInitialize? That
> seems a bit crazy.
> I am not for this "before PetcInitialize" strategy at all.
Why not. It was just stupidity on my part 20 years ago that I didn't think to make the various set options functions callable before PetscInitialize(). Better just to fix that oversight.
> However, I do think its far too fat. It initializes everything we can think of without
> giving the user and entry points in to customize it. That is compiler-level user disempowerment.
> I would rather see us rearchitect Init() so that you have better control over options, logging,
> CUDA, and all the other initializations hiding in there.
Make a concrete proposal. "better control" is pretty vague.
> Matt
> > Barry
> >> On Apr 22, 2018, at 5:54 PM, Jed Brown <jed at jedbrown.org> wrote:
> >> For users that read their own configuration files and/or choose
> >> PetscOptionsInsertFile after PetscInitialize, we don't have a good way
> >> to avoid overwriting PETSC_OPTIONS or command-line options. The user
> >> could manually find argv and the environment variable, but that's a poor
> >> abstraction. Should PetscOptionsInsertFile learn how to behave so as to
> >> add new entries to the options database, but not supersede any that
> >> already exist?
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
