[petsc-dev] Figures 20, 21 in Chapter 13.1 of PETSc manual are out of date
Junchao Zhang
jczhang at mcs.anl.gov
Thu Apr 19 09:30:18 CDT 2018
Hi, Patrick,
It is great if you can update it. I am still learning PETSc and the
manual.
BTW, I found ex10.c contains out-of-date comments, which were there for
the profiling manual, but the code diverged from the comments. Maybe you
can create a new test for the manual and add comments saying the test is
for the manual so that one will not accidentally overwrite it.
--Junchao Zhang
On Thu, Apr 19, 2018 at 1:01 AM, Patrick Sanan <patrick.sanan at gmail.com>
wrote:
> Sorry I didn't catch this when cleaning up the manual recently. If you
> don't have time to update it yourself, let me know and I will.
> 2018-04-19 5:23 GMT+02:00 Karl Rupp <rupp at iue.tuwien.ac.at>:
>> Hi Junchao,
>> 1) The manual says the example is src/ksp/ksp/examples/ex10.c, but it
>>> actually links to src/ksp/ksp/examples/tutorial/ex10.c. This is a minor
>>> issue.
>>> 2) One could not use the same command line options (-f0 medium -f1
>>> arco6) as shown in the figures. There are no such matrices so one can't
>>> simply copy & paste.
>>> 3) It seems ex10.c had gone through large changes and it can not produce
>>> a log summary similar to the figures anymore (e.g., no stages like "Event
>>> Stage 4: KSPSetUp 1" ).
>> such things (unfortunately) tend to happen over time. Please feel free to
>> fix it :-)
>> Best regards,
>> Karli
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180419/eee90d63/attachment.html>
