[petsc-dev] Is mpich/master:a8a2b30fd21 tested with Petsc?
Satish Balay
balay at mcs.anl.gov
Mon Apr 16 22:31:07 CDT 2018
On Tue, 13 Mar 2018, Eric Chamberland wrote:
> Hi,
> each night we are testing mpich/master with our petsc-based code. I don't
> know if PETSc team is doing the same thing with mpich/master? (Maybe it is a
> good idea?)
> Everything was fine (except the issue
> https://github.com/pmodels/mpich/issues/2892) up to commit 7b8d64debd, but
> since commit mpich:a8a2b30fd21), I have a segfault on a any parallel nightly
> test.
I attempted a bisect of the above range of commits - and narrowed down to:
db11d4c4a70e39a28be88ed32f00542301699e08 is the first bad commit
balay at asterix /home/balay/soft/build/mpich ((db11d4c4a...)|BISECTING)
$ git show db11d4c4a70e39a28be88ed32f00542301699e08
commit db11d4c4a70e39a28be88ed32f00542301699e08 (HEAD, refs/bisect/bad)
Author: Ken Raffenetti <raffenet at mcs.anl.gov>
Date: Thu Feb 15 11:37:59 2018 -0600
init: Fix tag upper limit initialization
The starting point for this value is equivalent to the usable tag bits
macro. This value should be set before device initialization,
otherwise devices will assume they have more bits than are actually
available.
Signed-off-by: Wesley Bland <wesley.bland at intel.com>
diff --git a/src/mpi/init/initthread.c b/src/mpi/init/initthread.c
index cbc41f4d5..b31ae2f07 100644
--- a/src/mpi/init/initthread.c
+++ b/src/mpi/init/initthread.c
@@ -403,7 +403,7 @@ int MPIR_Init_thread(int *argc, char ***argv, int required, int *provided)
MPIR_Process.attrs.host = MPI_PROC_NULL;
MPIR_Process.attrs.io = MPI_PROC_NULL;
MPIR_Process.attrs.lastusedcode = MPI_ERR_LASTCODE;
- MPIR_Process.attrs.tag_ub = 0;
+ MPIR_Process.attrs.tag_ub = MPIR_TAG_USABLE_BITS;
MPIR_Process.attrs.universe = MPIR_UNIVERSE_SIZE_NOT_SET;
MPIR_Process.attrs.wtime_is_global = 0;
@@ -531,13 +531,6 @@ int MPIR_Init_thread(int *argc, char ***argv, int required, int *provided)
MPIR_Assert(((unsigned) MPIR_Process.
attrs.tag_ub & ((unsigned) MPIR_Process.attrs.tag_ub + 1)) == 0);
- /* Set aside tag space for tagged collectives and failure notification */
-#ifdef HAVE_TAG_ERROR_BITS
- MPIR_Process.attrs.tag_ub >>= 3;
-#else
- MPIR_Process.attrs.tag_ub >>= 1;
-#endif
/* Assert: tag_ub is at least the minimum asked for in the MPI spec */
MPIR_Assert(MPIR_Process.attrs.tag_ub >= 32767);
Reverthing this patch gets mpich-3.3b2 working with petsc
Satish
