[petsc-dev] [petsc-users] PetscPrintf
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Mon Apr 16 16:53:56 CDT 2018
  Rongliang,
   I have prepared a fix for this in the branch barry/bugfix-petscformatconvert which comes from the master branch of PETSc.
   Unfortunately it requires many changes so cannot be back ported to previous releases.
   Thanks for reporting the problem,
    Barry
> On Apr 11, 2018, at 6:17 PM, Rongliang Chen <rongliang.chan at gmail.com> wrote:
> Dear All,
> When I tried to print a long string using PetscPrintf() I found that it truncated the string. Attached is a simple example for this (run with single processor). I used PetscPrintf() and printf() to print the same string and the printf() seems OK. I am using petsc-3.8.4.
> Best,
> Rongliang
> <ex111.c>
