[petsc-dev] git repo branches housekeeping
    Satish Balay
    balay at mcs.anl.gov
    Sun Apr  8 01:50:53 CDT 2018
On Sun, 8 Apr 2018, Satish Balay wrote:
> For more housekeeping - look at the remaining local and remote
> branches and figure-out what to do. [perhaps some of them are
> intermediate branches during rebase - or abandoned features that
> should be deleted].
For reference - current list of remote branches
Satish
$ git branch -r |wc -l
265
$ git branch -r
  origin/BarryFSmith/readmemd-created-online-with-bitbucket-1506004176072
  origin/HEAD -> origin/master
  origin/adams/zeroDSOR
  origin/balay/atpesc-tutorial-2014-bgq
  origin/balay/atpesc-tutorial-2015-bgq
  origin/balay/atpesc-tutorial-2016-bgq
  origin/balay/fix-ctable-hash-again/maint
  origin/balay/fix-cxx-cmplx-single
  origin/balay/fix-rebuild-xsdktrilinos
  origin/balay/fix-superlu_dist-reuse-factornumeric1-maint-backport
  origin/balay/fix-uninstall
  origin/balay/giturl-fixes
  origin/balay/k-fujitsu-f90-v3.6
  origin/balay/test
  origin/balay/to-maint-switch-hdf5-build-to-cmake
  origin/balay/update-builder-test
  origin/balay/update-elemental-nov-2016
  origin/barry-test
  origin/barry/clarify-dmplex-documentation
  origin/barry/feature-baij-blockdiagonal-scale
  origin/barry/feature-petscviewerformat-register
  origin/barry/fix-zoltan-library-list/maint
  origin/barry/improve-secant-linesearch
  origin/barry/oana/spectral-toy-updates
  origin/barry/pyjac
  origin/barry/refactor-vecview
  origin/barry/saws-profile
  origin/barry/spectral-poisson
  origin/barry/ssisc-spectral-adjoint
  origin/bueler/clean-ex9
  origin/dalcinl/fix-xaij-spd
  origin/dalcinl/math-isclose
  origin/dalcinl/ts-snes
  origin/damalbel/dmnetwork_nest
  origin/damalbel/dmnetwork_nest_fieldsplit
  origin/debo/mat-taij
  origin/debo/ts-fix-ex31
  origin/debo/ts-irk
  origin/denera/snes-reasonview-indent-fix
  origin/denera/tao-anderson-multisecant
  origin/denera/tao-bounded-newton
  origin/denera/tao-linesearch-redesign
  origin/denera/tao-lmvm-recycling-bounded-refactor
  origin/denera/tao-merge-pgd-into-bncg
  origin/denera/tao-separate-quadratic-solvers
  origin/dmay/ksp-cvgtest-normtype-fix
  origin/emil/add-fortran-ts-pre-post-stage-step/maint
  origin/emil/fix-ts-dae-rebased-v2
  origin/emil/ts-steady-state-ex31
  origin/haplav/feature-dmplex-distributed-hdf5-read
  origin/hongzh/change-memkind-default
  origin/hongzh/remove-manual-unrolling
  origin/hongzh/swe
  origin/hongzh/symplectic-integrator
  origin/hongzh/timing_issue
  origin/hongzh/ts-matshell-example
  origin/hongzh/vectorize-inner-products
  origin/hzhang/add-matcompress
  origin/hzhang/dmnetwork-couple
  origin/hzhang/fix-mpi3_unusedvar
  origin/hzhang/fix-ptaptest
  origin/hzhang/ksp-fminres
  origin/hzhang/ksp-minresqlp
  origin/hzhang/vec_node/master
  origin/hzhang/vec_node/master-rebased
  origin/irving/fe-scalars
  origin/irving/snes-ex12-cleanup
  origin/jczhang/feature-vecscatter-mpi3shmem
  origin/jczhang/optimize-on-node-matrix
  origin/jczhang/optimize-vecscatter-multi-copy
  origin/jed/assembly-perf
  origin/jed/cray-externc
  origin/jed/defined-nocpp
  origin/jed/doc-xsetdm
  origin/jed/elbueler-snes-ex5-fixes
  origin/jed/feature-dmda-section
  origin/jed/feature-sf-local
  origin/jed/fix-mat-convert-basic-bs
  origin/jed/ksp-plugin
  origin/jed/make-lib-ordering
  origin/jed/mat-eigenvalue-cache
  origin/jed/mat-hash
  origin/jed/mat-kaij
  origin/jed/mat-taij
  origin/jed/matbaij-loop
  origin/jed/matzerorowscolumnslocal-null/maint
  origin/jed/mpi-2
  origin/jed/next-seaice
  origin/jed/sr-driver
  origin/jed/sr-driver4
  origin/jed/tao-status-string
  origin/jed/tap
  origin/jed/testsrcs-refresh
  origin/jed/ts-ex11-union
  origin/jed/ts-heat-plex
  origin/jed/vecghostgetvalues
  origin/john-saws-webosocket-update
  origin/john/saws-webui-upgrade
  origin/karlrupp/feature-fast-matmatmult
  origin/karlrupp/feature-optimize-opencl-petscfe
  origin/karlrupp/feature-pipelined-cg-viennacl
  origin/karlrupp/feature-viennacl-cuda
  origin/karlrupp/feature-viennacl-openmp
  origin/karlrupp/fix-viennacl-veccopy
  origin/karpeev/fix-pc-fieldsplit-reset
  origin/karpeev/mat-convert-nest-aij-test
  origin/karpeev/mat-reset
  origin/klaij/fieldsplit-simple-ex70
  origin/knepley/feature-configure-kcomputer
  origin/knepley/feature-da-repartition
  origin/knepley/feature-error-logging
  origin/knepley/feature-fe-nonaffine
  origin/knepley/feature-optcontrol-mg
  origin/knepley/feature-pc-patch
  origin/knepley/feature-plex-example-nonconforming
  origin/knepley/feature-plex-functionals
  origin/knepley/feature-plex-l2-projection
  origin/knepley/feature-plex-nasm
  origin/knepley/feature-plex-parallel-submesh
  origin/knepley/feature-plex-snesvi-example
  origin/knepley/feature-snes-ex13-spectral
  origin/knepley/feature-snes-rewrite
  origin/knepley/feature-spectral-solutions
  origin/knepley/fix-dm-gmg
  origin/knepley/fix-ex62-tests
  origin/knepley/fix-fe-bd-integral
  origin/knepley/fix-fe-vector-spaces
  origin/knepley/fix-plex-hdf5-periodic
  origin/knepley/fix-plex-pointfunc-dim
  origin/knepley/fix-quadrature-order
  origin/knepley/fix-snes-ex69
  origin/knepley/ibamr
  origin/knepley/pylith
  origin/madams/ex56params
  origin/madams/sor-residual
  origin/madams/sr-driver
  origin/madams/sr-driver2
  origin/madams/sr-driver4
  origin/madams/sr1
  origin/maint
  origin/maint-3.2
  origin/maint-3.3
  origin/maint-3.4
  origin/maint-3.5
  origin/maint-3.6
  origin/maint-3.7
  origin/maint-3.8
  origin/maint-tao-2.2
  origin/mark/aij-overlap
  origin/mark/dm-bs-bug
  origin/mark/dmplex-generalize-periodicity
  origin/mark/ex48-jacobian
  origin/mark/feature-picell
  origin/mark/feature-plex-l2-projection
  origin/mark/fix-mat2
  origin/mark/mat-fix-scale
  origin/mark/plex-tuts
  origin/mark/ts-ex11-mhd
  origin/master
  origin/master-tao
  origin/mlange/feature-plex-case
  origin/mlange/feature-plex-create-parallel
  origin/mlange/feature-plex-triangle
  origin/mlange/fix-adjacency-performance
  origin/mlange/fix-plex-cas-tests
  origin/mlange/fix-plex-hex-mesh
  origin/mlange/plex-create-parallel
  origin/mlange/plex-distributed-overlap
  origin/mlange/plex-hybrid-hdf5
  origin/mlange/plex-redistribute
  origin/mlange/plex-sfc-reordering
  origin/mlange/plex-vertex-partitioning
  origin/mlange05/fix-gmsh-coordinates
  origin/next
  origin/next-apr-2016
  origin/next-apr-2018
  origin/next-jun-2015
  origin/next-jun-2017
  origin/next-may-2016
  origin/next-nov-2017
  origin/next-oct-2014
  origin/next-sep-2017
  origin/next-tmp
  origin/oana/spectral-toy
  origin/paulmullowney/aijcusp-ellpack-fix
  origin/pefarrell/dmshell-asm
  origin/pefarrell/nasm-fixes
  origin/peller/threadcomm
  origin/pr118/asmunder/DMDA-fortran-example/master
  origin/pr478/pfarrell/feature-dmplex-adapt
  origin/pr600/dmeiser/feature-examples-newmethod/master
  origin/prbrune/matcoloring-creategraph
  origin/prbrune/matcoloring-minpack
  origin/prbrune/matcoloring-misimprovement
  origin/prbrune/matcoloring-zoltan
  origin/prbrune/pcgamg-bootstrap
  origin/prbrune/pcgamg-classicalbootstrap
  origin/prbrune/pcgamg-cr
  origin/prbrune/sf-examplefix
  origin/prbrune/snes-ex19vtkoutput
  origin/prbrune/snes-fasadditive
  origin/prbrune/zoltanupdate
  origin/psanan/ksp-tutorial-ex60-fixes
  origin/psanan/ts-bz-examples
  origin/psanan/ts-multiscale
  origin/psanan/ts-rhs-partitions
  origin/psanan/ts-tests
  origin/psanan/vec-mtdot-fix
  origin/rmills/feature-aijmkl-optional-sparse-optimize
  origin/rmills/feature-gamg-use-matsell
  origin/rmills/fix-sell-matconvert
  origin/sarich/feature-submatrixfree
  origin/sarich/feature-tao-pounders-jacobian
  origin/sarich/fix-alquimia-static
  origin/sarich/mira
  origin/sarich/snesvi-subvec-options
  origin/sarich/tao-pounders-add-corr-test
  origin/scott/change-NO_RM-default
  origin/scott/documentation-walker
  origin/scott/test-harness-debugger
  origin/scott/test-harness-perform2
  origin/scott/update-dm-dt-output
  origin/shri/FTRTDS-project
  origin/shri/dmnetwork-subnetworks
  origin/shri/ts-dae-semi-explicit
  origin/shri/ts-powergrid
  origin/stefano_zampini/feature-continuousadjoint
  origin/stefano_zampini/feature-matis-ptap-aij
  origin/stefano_zampini/feature-newmattype-elementlist
  origin/stefano_zampini/feature-pcgamg-useamat
  origin/stefano_zampini/new-elemental-interface
  origin/tisaac/buildsystem-feature-parallel
  origin/tisaac/buildsystem-feature-subst-link-flags
  origin/tisaac/config-fix-petsc-py
  origin/tisaac/darcy-inference
  origin/tisaac/dm-project-function-label
  origin/tisaac/dt-feature-vectur-quadrature
  origin/tisaac/dual-space-get-traces
  origin/tisaac/feature-dmfield
  origin/tisaac/feature-dmfield-orig
  origin/tisaac/feature-fe-integrate-nonaffine
  origin/tisaac/feature-gamg-compose-graph
  origin/tisaac/feature-picell
  origin/tisaac/feature-plex-example-nonconforming
  origin/tisaac/feature-seqaij-get-submat-row-unordered
  origin/tisaac/feature-seqaij-submat-col-unsorted
  origin/tisaac/feature-test-maxiter-filter
  origin/tisaac/fix-gamg-set-coordinates
  origin/tisaac/fix-height-ds
  origin/tisaac/gamg-more-info
  origin/tisaac/knepley/feature-composable-callbacks
  origin/tisaac/ksp-fix-cheby-pc-handling
  origin/tisaac/master-merge-mark-snesex56
  origin/tisaac/moab-update
  origin/tisaac/pc-pbjacobi-vec-get-array-read
  origin/tisaac/petsc-next-upstream
  origin/tisaac/plex-descriptive-debug
  origin/tisaac/plex-feature-vec-get-star
  origin/tisaac/plex-fv-without-ghosts
  origin/tisaac/update-p4est
  origin/tisaac/warn-next-upstream
  origin/tmunson/tao-feature-hessian-lagrangian
  origin/tmunson/tao-fix-leastsquares-tests
  origin/tmunson/tao-upgrade-tron
  origin/vi/snes-newtonaugas
