[petsc-dev] upcoming release and testing
Patrick Sanan
patrick.sanan at gmail.com
Thu Apr 5 11:13:40 CDT 2018
Spellcheck fixes for dev.html :
- relavant --> relevant
- diffencing --> differencing
- seperately --> separately
Patch also attached.
2018-04-05 17:03 GMT+02:00 Satish Balay <balay at mcs.anl.gov>:
> Thanks Karl!
> BTW: Its best to update dev.html in master [and then I can rebase
> balay/release-3.9 over master. This way - the commit in
> balay/release-3.9 is the final commit for the release - and traceable
> later]
> So i've moved this commit over to master.
> Satish
> On Thu, 5 Apr 2018, Karl Rupp wrote:
> > Hi Satish,
> > FYI: I added a mention of GPU backends available in the release and fixed
> > missing ul-tags in src/docs/website/documentation/changes/39.html in
> your
> > balay/release-3.9 branch.
> > Best regards,
> > Karli
> > On 04/02/2018 08:18 PM, Satish Balay wrote:
> > > All,
> > > It would be good if
> > > http://www.mcs.anl.gov/petsc/documentation/changes/dev.html is cheked
> and
> > > updated with any obvious missing stuff.
> > > Thanks,
> > > Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180405/8fd84d11/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180405/8fd84d11/attachment.obj>
