[petsc-dev] FAS indentation
    Satish Balay
    balay at mcs.anl.gov
    Thu Apr  5 08:28:40 CDT 2018
Matt,
Is this patch Alp sent - a fix for one of the outstanding issues? If so - which branch should it go into? [or will you check and add it in?]
Satish
On Wed, 4 Apr 2018, Dener, Alp wrote:
> Hi Matt,
> Some notes about this issue:
>  1.
>     Correction to my previous email: the XYZMonitor() routines were not touched/modified in this feature branch. I misspoke about that. We modified the XYZView()
>     only, and indeed these are the ones that appear to have some different indentations in the output files.
>  2.
>     I’m seeing incorrect tab levels in only two ex12 tests: ex12_tri_p1_adapt_0 and ex12_tri_p1_adapt_1. Turns out SNESReasonView() did not have the earlier tab
>     level changes correctly propagated into it. I’ve attached a git format-patch that fixes this (I didn’t wanna push directly to next without approval). But the
>     remaining tab level changes are consistent with the XYZView() changes we’ve made. So I would recommend updating the output files after applying the patch
>     (again, I didn’t want to touch the outputs without your approval first).
>  3.
>     Your first email on this mentioned FAS solver errors, but all the ex12_fas_% tests are passing for me locally. Can you confirm that these are working for you
>     as well? If not, which test machine should I run this on to reproduce your errors?
>  4.
>     I’ve got some number of the ex12 tests crashing on my machine. ex12_restart-b reports HDF5 errors, while ex12_mg_newton_coarse_0, ex12_mg_newton_coarse_1 and
>     ex12_mg_newton_coarse_2 report “inconsistent data” with regards to dof mapping. These just might have to do with my local configuration but I still wanted to
>     put it on your radar just in case.
> Thanks,
> — Alp Dener
> On April 3, 2018 at 6:24:42 PM, Matthew Knepley (knepley at gmail.com) wrote:
> On Tue, Apr 3, 2018 at 7:16 PM, Dener, Alp <adener at anl.gov> wrote:
>       Sure thing!
> Matt, just to give you a bit of detail, the Monitor() calls to ASCII viewers were changed to respect the tab levels for the parent objects instead of
> manually pushing and popping tabs on the printouts. The code also tries to preserve the existing tab levels of the viewer though — that is, we first
> save the existing tab level, then indent monitor printouts from the root (0 tab) using the object’s tab level, and then set the viewer back to whatever
> tab level it was at before the monitor is called. So in theory, it shouldn’t be changing the behavior of the viewer outside of the monitor. It is
> entirely possible I introduced a bug somewhere and that’s what I’m going to look for right now, but in the meantime please let me know if there’s a
> use-case or a test I can use for debugging as well.
> The easiest thing to do is run all the SNES ex12 tests in next and look at the indentation errors. I am now pushing fixes for all other errors, so
> by the time you run there should be nothing else.
>   Thanks,
>      Matt
>       Thanks,
>       — Alp Dener
> On April 3, 2018 at 6:11:12 PM, Smith, Barry F. (bsmith at mcs.anl.gov) wrote:
>       Alp,
>       Can you please take a look at this?
>       Thanks
>       Barry
>       > On Apr 3, 2018, at 4:46 PM, Matthew Knepley <knepley at gmail.com> wrote:
>       > The recent indentation fix (I think) has broken the FAS solver indentation.
>       > Matt
>       > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which
>       their experiments lead.
>       > -- Norbert Wiener
>       > https://www.cse.buffalo.edu/~knepley/
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
