[petsc-dev] Nullspace with right preconditioning
Wed Apr 4 14:27:11 CDT 2018
On Wed, Apr 4, 2018 at 3:23 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>   It may not be broken; it may just be misunderstood or incorrect approach.
>   You'll need to explain why and where exactly you think it is broken.
I am solving Stokes. I will push the example for you to run tonight.
Basically, I put in a constant for the pressure
as the nullspace. If you run with gmres/left it gives back a pressure with
integral 0. If you run with gmres/right,
it gives back a pressure with a big integral.
   Matt
>   Barry
> > On Apr 4, 2018, at 1:13 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > This is broken. Did we know this was broken?
> >   Thanks,
> >      Matt
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180404/9cb24b19/attachment.html>
