[petsc-dev] [issue1595] Issues of limited number of MPI communicators when having many instances of hypre boomerAMG with Moose 49d13fee5f3a3720
    Matthew Knepley
    knepley at gmail.com
    Tue Apr  3 17:09:17 CDT 2018
I have to be registered. I believe  there is also a suitcoat requirement
for the Hypre list.
   Matt
On Tue, Apr 3, 2018 at 6:03 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Apr 3, 2018 at 6:02 PM, Rob Falgout hypre Tracker <
> hypre-support at llnl.gov> wrote:
>> Rob Falgout <rfalgout at llnl.gov> added the comment:
>> In my opinion, if the user is doing something simultaneously with a hypre
>> solve (not the typical case, I think), then they should be responsible for
>> ensuring that the communicators don't conflict.  It will also be easier to
>> control the number of communicators used in those situations where there
>> are limits.
> That seems like a solipsistic way to operate, and it does not scale very
> well. Substitute "other library" for "user" in
> what you said. Now all libraries but Hypre must protect themselves from
> Hypre messages. Why is Hypre special?
> Doesn't it seem like you guys should segregate your messages into a
> different space?
>    Matt
>> Just my 2 cents.
>> -Rob
>> ____________________________________________
>> hypre Issue Tracker <hypre-support at llnl.gov>
>> <http://cascb1.llnl.gov/hypre/issue1595>
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180403/835ecc76/attachment.html>
