[petsc-dev] [issue1595] Issues of limited number of MPI communicators when having many instances of hypre boomerAMG with Moose
Rob Falgout hypre Tracker hypre-support at llnl.gov
Tue Apr 3 15:12:03 CDT 2018
Rob Falgout <rfalgout at llnl.gov> added the comment:
Hi Barry,
Can you explain the scenario where multiple hypre solves would be working in parallel with the same communicator?  Thanks!
-Rob
____________________________________________
hypre Issue Tracker <hypre-support at llnl.gov>
<http://cascb1.llnl.gov/hypre/issue1595>
