[petsc-dev] why am I getting this message?
    Satish Balay
    balay at mcs.anl.gov
    Wed Sep 27 10:05:46 CDT 2017
If you are indeed on 3.8 - and petscnagupgrade.py gave a warning -
then something was not right..
Well as long as you've verified that you are on 3.8 - it should be
fine.
Satish
On Wed, 27 Sep 2017, Mark Adams wrote:
> Well I am on v3.8 now and I did pull ... oh well, not a biggy.
> On Wed, Sep 27, 2017 at 9:27 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > petscnagupgrade.py will check and nag you only once a day.
> > You should verify if you have 3.8 - with 'git log' or 'git describe'
> > Satish
> > > This message seems to have gone away ...
> > > On Wed, Sep 27, 2017 at 8:14 AM, Mark Adams <mfadams at lbl.gov> wrote:
> > > > I just pulled maint but still get a message that I am out of date:
> > > > 1072  git pull origin
> > > >  1073  h
> > > > 05:12 cori01 maint= ~/petsc_install/petsc$
> > ../arch-cori-knl-opt-intel.py
> > > > PETSC_DIR=$PWD
> > > > The version of PETSc you are using is out-of-date, we recommend
> > updating
> > > > to the new release
> > > >  Available Version: 3.8   Installed Version: 3.7.6
> > > > http://www.mcs.anl.gov/petsc/download/index.html
> > > >              Configuring PETSc to compile on your system
