[petsc-dev] why am I getting this message?
Wed Sep 27 08:27:00 CDT 2017
petscnagupgrade.py will check and nag you only once a day.
You should verify if you have 3.8 - with 'git log' or 'git describe'
Satish
On Wed, 27 Sep 2017, Mark Adams wrote:
> This message seems to have gone away ...
> On Wed, Sep 27, 2017 at 8:14 AM, Mark Adams <mfadams at lbl.gov> wrote:
> > I just pulled maint but still get a message that I am out of date:
> > 1072  git pull origin
> >  1073  h
> > 05:12 cori01 maint= ~/petsc_install/petsc$ ../arch-cori-knl-opt-intel.py
> > PETSC_DIR=$PWD
> > The version of PETSc you are using is out-of-date, we recommend updating
> > to the new release
> >  Available Version: 3.8   Installed Version: 3.7.6
> > http://www.mcs.anl.gov/petsc/download/index.html
> >              Configuring PETSc to compile on your system
