[petsc-dev] DMCoarsenHookAdd in SNESSetUpMatrices
    Stefano Zampini
    stefano.zampini at gmail.com
    Mon Sep 25 10:37:46 CDT 2017
Jed,
Today I fought for several hours against a strange behaviour occuring when
reusing a TS for multiple solves. You can reproduce it by applying the
attached patch.
The issue is with DMCoarsenHookAdd called in SNESSetUpMatrices, and git
blames you ;-).
Every time you call TSGetRHSMats_Private, TSGetIJacobian gets called, which
in turns calls SNESSetUpMatrices, that adds the entry in the linked list of
hooks via DMCoarsenHookAdd. This causes a considerable slow down when using
the RHS interface with an implicit solver, as you can see from running the
patched code.
can you please take a look?
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170925/7fb9d0f7/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170925/7fb9d0f7/attachment.obj>
