[petsc-dev] Question about linesearch
Lulu Liu
lulu.liu at kaust.edu.sa
Fri Sep 22 08:22:39 CDT 2017
I am trying to find a lambda by the linesearch such that
f([x_{k}+\lambda d_{k}])<f(x_{k})+\alpha\lambda grad f(x_{k})^{T}d_{k}
where [x_{k}+lambda d_{k}] means the projection that cuts off the
undershoot or overshoot of x_{k}+lambda d_{k}.
How to add the above projection into the linesearch in PETSc?
Thanks!
This message and its contents, including attachments are intended solely
for the original recipient. If you are not the intended recipient or have
received this message in error, please notify me immediately and delete
this message from your computer system. Any unauthorized use or
distribution is prohibited. Please consider the environment before printing
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170922/7b9d8306/attachment.html>
