[petsc-dev] HDF5 error from GAMG
Mark Adams
mfadams at lbl.gov
Mon Sep 18 19:44:43 CDT 2017
I get this strange error when I use GAMG, in parallel. I don't see it in
serial and I don't see it with the default solver.
The problem seems to be that I use -vec_view in my code and the guts of Vec
seem to be picking this up and causing havoc. In the past I have added a
prefix to my -[x2_]vec_view and that seemed to work, but I would like to
try to fix this and not shove it under the carpet again, if possible.
It looks like a call to VecAssemblyEnd in the guts of GAMG is calling
PetscObjectViewFromOptions. I don't understand why this only happens in
parallel.
Any ideas?
20:27 master= ~/Codes/picell/src$ make run NP=4
/Users/markadams/Codes/petsc/arch-macosx-gnu-g/bin/mpiexec -n 4
./picell.arch-macosx-gnu-g -petscspace_poly_tensor -petscspace_order 1
-mstep 2 -debug 3 -snes_monitor -ksp_monitor -snes_converged_reason
-dm_refine 4 -dt .1 -use_bsp 10 -num_particles_proc -1 -num_phi_cells 8
-dm_view hdf5:sol.h5 -vec_view hdf5:sol.h5::append -dm_plex_periodic_cut
[0] **** Warning ****, no global point location. multiple processors (4)
not supported
[0] npe=4; 2 x 2 x 1 flux tube grid; mpi_send size (chunksize) has 64
particles. ions only, BSP communication, phi section = 6.28319
createMesh ntheta_total=4.
[0] 961 equations on 4 processors, 256 local cells, (element 0 used for
flux tube list)
DM Object: Parallel Mesh 4 MPI processes
type: plex
Parallel Mesh in 2 dimensions:
0-cells: 289 289 289 289
1-cells: 544 544 544 544
2-cells: 256 256 256 256
Labels:
boundary: 1 strata with value/size (1 (65))
Face Sets: 2 strata with value/size (1 (31), 4 (31))
marker: 1 strata with value/size (1 (65))
depth: 3 strata with value/size (0 (289), 1 (544), 2 (256))
[0]shiftParticles: BSP have 1 for proc 0
[0]shiftParticles: BSP have 1 particles for proc 0
(1 chunks)
[0]shiftParticles: BSP sent 1
[2]shiftParticles: BSP sent 0
[3]shiftParticles: BSP sent 0
[1]shiftParticles: BSP sent 0
0) 1 local particles, 1/1 global, 0. % total particles moved in 0 messages
total (to 1 processors local), 4. load imbalance factor
0 SNES Function norm 6.176014522980e-01
0 KSP Residual norm 2.033453504856e+00
1 KSP Residual norm 1.247246018913e-01
2 KSP Residual norm 7.169223999741e-03
3 KSP Residual norm 3.494127469709e-04
4 KSP Residual norm 1.539576656127e-05
1 SNES Function norm 7.013048909984e-06
0 KSP Residual norm 1.539576656641e-05
1 KSP Residual norm 1.233278209501e-06
2 KSP Residual norm 6.474128793205e-08
3 KSP Residual norm 3.824829808334e-09
4 KSP Residual norm 1.813659764651e-10
5 KSP Residual norm 3.684110934970e-12
2 SNES Function norm 2.386983413511e-12
Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 2
[0]shiftParticles: BSP have 0 for proc 0
[0]shiftParticles: BSP have 1 for proc 2
[0]shiftParticles: BSP have 1 particles for proc 2
(1 chunks)
1) 1 local particles, 1/1 global, 100. % total particles moved in 0
messages total (to 2 processors local), 4. load imbalance factor
0 SNES Function norm 6.828943707479e-01
HDF5-DIAG: Error detected in HDF5 (1.8.18) HDF5-DIAG: Error detected in
HDF5 (1.8.18) MPI-process 3:
#000: H5F.c line 604 in H5Fopen(): unable to open file
major: File accessibilty
minor: Unable to open file
#001: H5Fint.c line 1087 in H5F_open(): unable to read superblock
minor: Read failed
#002: H5Fsuper.c line 294 in H5F_super_read(): unable to load superblock
major: Object cache
minor: Unable to protect metadata
#003: H5AC.c line 1262 in H5AC_protect(): H5C_protect() failed.
major: Object cache
#004: H5C.c line 3574 in H5C_protect(): can't load entry
major: Object cache
minor: Unable to load metadata into cache
#005: H5C.c line 7954 in H5C_load_entry(): unable to load entry
major: Object cache
HDF5-DIAG: Error detected in HDF5 (1.8.18) MPI-process 1:
minor: Read failed
major: Object cache
major: Object cache
major: Object cache
major: Object cache
#006: H5Fsuper_cache.c line 476 in H5F_sblock_load(): truncated file: eof
= 365072, sblock->base_addr = 0, stored_eoa = 367568
minor: File has been truncated
[snip]
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Error in external library
[0]PETSC ERROR: Error in HDF5 call H5Fopen() Status -1
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.7.6-5541-gd07ad3ccba
GIT Date: 2017-09-17 13:49:32 -0400
[0]PETSC ERROR: ./picell.arch-macosx-gnu-g on a arch-macosx-gnu-g named
MarksMac-5.local by markadams Mon Sep 18 20:27:26 2017
[0]PETSC ERROR: Configure options --with-cc=clang --with-cc++=clang++
COPTFLAGS="-g -mavx2" CXXOPTFLAGS="-g -mavx2" FOPTFLAGS="-g -mavx2"
--download-mpich=1 --download-hypre=1 --download-metis=1
--download-parmetis=1 --download-c2html=1 --download-ctetgen
--download-p4est=1 --download-superlu_dist --download-superlu
--download-triangle=1 --download-hdf5=1 --download-zlib --with-x=0
--with-debugging=1 PETSC_ARCH=arch-macosx-gnu-g --download-chaco
--with-viewfromoptions=1
[0]PETSC ERROR: #1 PetscViewerFileSetName_HDF5() line 242 in
/Users/markadams/Codes/petsc/src/sys/classes/viewer/impls/hdf5/hdf5v.c
[0]PETSC ERROR: #2 PetscViewerFileSetName() line 650 in
/Users/markadams/Codes/petsc/src/sys/classes/viewer/impls/ascii/filev.c
[0]PETSC ERROR: #3 PetscOptionsGetViewer() line 339 in
/Users/markadams/Codes/petsc/src/sys/classes/viewer/interface/viewreg.c
[0]PETSC ERROR: #4 PetscObjectViewFromOptions() line 2773 in
/Users/markadams/Codes/petsc/src/sys/objects/options.c
[0]PETSC ERROR: #5 VecAssemblyEnd() line 182 in
/Users/markadams/Codes/petsc/src/vec/vec/interface/vector.c
[0]PETSC ERROR: #6 PCGAMGGetDataWithGhosts() line 376 in
/Users/markadams/Codes/petsc/src/ksp/pc/impls/gamg/util.c
[0]PETSC ERROR: #7 PCGAMGProlongator_AGG() line 1071 in
/Users/markadams/Codes/petsc/src/ksp/pc/impls/gamg/agg.c
[0]PETSC ERROR: #8 PCSetUp_GAMG() line 519 in
/Users/markadams/Codes/petsc/src/ksp/pc/impls/gamg/gamg.c
[0]PETSC ERROR: #9 PCSetUp() line 924 in
/Users/markadams/Codes/petsc/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #10 KSPSetUp() line 378 in
/Users/markadams/Codes/petsc/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #11 KSPSolve() line 609 in
[0]PETSC ERROR: #12 SNESSolve_NEWTONLS() line 224 in
/Users/markadams/Codes/petsc/src/snes/impls/ls/ls.c
[0]PETSC ERROR: #13 SNESSolve() line 4106 in
/Users/markadams/Codes/petsc/src/snes/interface/snes.c
[0]PETSC ERROR: #14 DMPICellSolve() line 18 in
/Users/markadams/Codes/petsc/src/snes/utils/dmpicellsnes.c
[0]PETSC ERROR: #15 go() line 1120 in
/Users/markadams/Codes/picell/src/main.c
[0]PETSC ERROR: #16 main() line 1304 in
[0]PETSC ERROR: PETSc Option Table entries:
[0]PETSC ERROR: -debug 3
[0]PETSC ERROR: -dm_plex_periodic_cut
[0]PETSC ERROR: -dm_refine 4
[0]PETSC ERROR: -dm_view hdf5:sol.h5
[0]PETSC ERROR: -dt .1
[0]PETSC ERROR: -ksp_monitor
[0]PETSC ERROR: -ksp_type cg
[0]PETSC ERROR: -mstep 2
[0]PETSC ERROR: -num_particles_proc -1
[0]PETSC ERROR: -num_phi_cells 8
[0]PETSC ERROR: -options_left
[0]PETSC ERROR: -pc_type gamg
[0]PETSC ERROR: -petscspace_order 1
[0]PETSC ERROR: -petscspace_poly_tensor
[0]PETSC ERROR: -snes_converged_reason
[0]PETSC ERROR: -snes_monitor
[0]PETSC ERROR: -use_bsp 10
[0]PETSC ERROR: -vec_view hdf5:sol.h5::append
[0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 0
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170918/e3809f99/attachment.html>
