[petsc-dev] TSComputeRHSJacobian
Stefano Zampini
stefano.zampini at gmail.com
Thu Sep 14 04:47:01 CDT 2017
Fair enough.
Here you have an example. You need to checkout the
branch stefano_zampini/feature-continuousadjoint and apply patch_ex23 to
src/ts/examples/tutorials/ex23.c
The patch just dumps the final RHS jacobian matrix of a standard TSSolve,
recomputes it with by calling TSComputeRHSJacobian, and dumps it again.
If you run ex23 using the RHS interface and an implicit solver, you see
from the first MatView that ts->Arhs is shifted. After a call to
TSComputeRHSJacobian it is ok.
[szampini at localhost tutorials]$ ./ex23 -t0 0 -tf 1 -dt 0.5 -p 1 -ts_type bdf
Mat Object: 1 MPI processes
type: seqaij
row 0: (0, 13.2008)
type: seqaij
row 0: (0, 0.7)
Objective function: time [0.,1.], val 0.725152 (should be 0.724109)
Vec Object: 1 MPI processes
type: seq
1.45054
0.404627
-0.126697
If you apply patch_ts (which disables my fix at
https://bitbucket.org/petsc/petsc/branch/stefano_zampini/feature-continuousadjoint#Lsrc/ts/interface/ts.cT614),
you see that the matrix is unchanged after TSComputeRHSJacobian
type: seqaij
row 0: (0, 13.2008)
type: seqaij
row 0: (0, 13.2008)
type: seq
1.45054
0.404627
-0.126697
2017-09-10 22:43 GMT+03:00 Barry Smith <bsmith at mcs.anl.gov>:
> Stefano,
> Thanks, but I don't really want a fix. I want a code that I can run
> that demonstrates a problem (then we can evaluate fixes)
> Barry
> > On Sep 8, 2017, at 11:51 AM, Stefano Zampini <stefano.zampini at gmail.com>
> wrote:
> > I encountered the problem while working on the adjoint code. Here is the
> fix I have in my branch
> feature-continuousadjoint#Lsrc/ts/interface/ts.cT613
> > However, I'm not sure if this is a problem just with my code. This is
> why I'm asking on the list.
> > 2017-09-08 0:02 GMT+03:00 Barry Smith <bsmith at mcs.anl.gov>:
> > Example that demonstrates the current code is problematic in some
> cases?
> > > On Aug 28, 2017, at 11:59 AM, Stefano Zampini <
> stefano.zampini at gmail.com> wrote:
> > > I was wondering if the following code in TSComputeRHSJacobian is
> correct when the user pass the reuse flag via TSRHSJacobianReuse
> > > if (ts->rhsjacobian.time == t && (ts->problem_type == TS_LINEAR ||
> (ts->rhsjacobian.Xid == Uid && ts->rhsjacobian.Xstate == Ustate)) &&
> (rhsfunction != TSComputeRHSFunctionLinear)) {
> > > PetscFunctionReturn(0);
> > > Should the above code be replaced by the following?
> > > if (ts->rhsjacobian.reuse) {
> > > ierr = MatShift(A,-ts->rhsjacobian.shift);CHKERRQ(ierr);
> > > ierr = MatScale(A,1./ts->rhsjacobian.scale);CHKERRQ(ierr);
> > > if (B && A != B) {
> > > ierr = MatShift(B,-ts->rhsjacobian.shift);CHKERRQ(ierr);
> > > ierr = MatScale(B,1./ts->rhsjacobian.scale);CHKERRQ(ierr);
> > > ts->rhsjacobian.shift = 0;
> > > ts->rhsjacobian.scale = 1.;
> > > Stefano
> > Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170914/2030287b/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170914/2030287b/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170914/2030287b/attachment-0001.obj>
