[petsc-dev] PetscSF in Fortran
Jed Brown
jed at jedbrown.org
Tue Oct 31 22:20:19 CDT 2017
Adrian Croucher <a.croucher at auckland.ac.nz> writes:
> On 01/11/17 09:50, Smith, Barry F. wrote:
>> Please send the full traceback. Cut and paste
> It's not really giving me much, only:
> Program received signal SIGSEGV, Segmentation fault.
> 0x00007efe8574d6a9 in Pack_int_1 (n=2, bs=1, idx=0xfd6430,
> unpacked=0xfffffffb000003ec, packed=0xfe9a00)
> at /home/acro018/software/PETSc/code/src/vec/is/sf/impls/basic/sfbasic.c:497
> 497 DEF_PackCmp(int)
You need to use "bt" (backtrace) to print the rest of the stack.
Can you give instructions to reproduce on a different system? Does
Valgrind have warnings?
