[petsc-dev] Segfault in DMPlexVecGetClosure
    Blaise A Bourdin
    bourdin at lsu.edu
    Tue Oct 31 13:08:53 CDT 2017
On Oct 31, 2017, at 12:39 PM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Tue, Oct 31, 2017 at 11:36 AM, Blaise A Bourdin <bourdin at lsu.edu<mailto:bourdin at lsu.edu>> wrote:
I am losing my mind over segfaults in DMPlexVecGetClosure.
In the example below, I get a segfault whenever cval is not set to NULL before calling DMPlexVecGetClosure. Is this expected?
Yes. If cval is NULL, it allocates the necessary space and passes back the array. If it is not NULL, it uses the pointer that you passed
in (so you can allocate your own temp storage if you are smarter).
The documentations says nothing about this
That is a problem.
Also, after calling DMPlexVecRestoreClosure, the values of cval are discarded and neither global nor coord are changed.
Ah, GetClosure() is not like GetArray(), in that it is a temp copy. You need SetClosure() in order to change values.
So DMPlexVecGetClosure / DMPlexVecRestoreClosure behaves more like ISCreateGeneral / ISDestroy than as a standard PETSc XXXGet / XXXRestore.
I’ll do my best to submit a pull request with an updated man page and an example.
Blaise
   Matt
I am obviously doing something wrong but cannot figure it out...
Blaise
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612<tel:(225)%20578-1612>, Fax  +1 (225) 578 4276<tel:(225)%20578-4276> http://www.math.lsu.edu/~bourdin
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.caam.rice.edu/~mk51/>
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171031/5d1b483d/attachment-0001.html>
