[petsc-dev] Segfault in DMPlexVecGetClosure
Blaise A Bourdin
bourdin at lsu.edu
Tue Oct 31 10:36:51 CDT 2017
I am losing my mind over segfaults in DMPlexVecGetClosure.
In the example below, I get a segfault whenever cval is not set to NULL before calling DMPlexVecGetClosure. Is this expected? The documentations says nothing about this
Also, after calling DMPlexVecRestoreClosure, the values of cval are discarded and neither global nor coord are changed.
I am obviously doing something wrong but cannot figure it out...
Blaise
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171031/357691b6/attachment.html>
Desc: EXOTest7.c
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171031/357691b6/attachment.obj>
Desc: out2.gen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171031/357691b6/attachment-0001.obj>
