[petsc-dev] SLEPc failure
Sat Oct 28 19:00:10 CDT 2017
On Sat, Oct 28, 2017 at 7:11 AM, Franck Houssen <franck.houssen at inria.fr>
wrote:
> I just added that before EPSSetOperators:
> PetscViewer viewerA; PetscViewerBinaryOpen(PETSC_
> COMM_WORLD,"Atau.out",FILE_MODE_WRITE,&viewerA); MatView(A,viewerA);
> PetscViewer viewerB; PetscViewerBinaryOpen(PETSC_
> COMM_WORLD,"Btau.out",FILE_MODE_WRITE,&viewerB); MatView(B,viewerB);
> At first, I avoided binary as I didn't know if the format handles
> big/little endianness... So I prefered ASCII.
Everything is big endian. We convert it from that to what we need on the
machine.
   Matt
> Binary data are attached.
> Franck
> PS : running debian with little endian.
> >> python -c "import sys;print(0 if sys.byteorder=='big' else 1)"
> 1
> ----- Mail original -----
> > De: "Jose E. Roman" <jroman at dsic.upv.es>
> > À: "Franck Houssen" <franck.houssen at inria.fr>
> > Cc: "For users of the development version of PETSc" <
> petsc-dev at mcs.anl.gov>
> > Envoyé: Vendredi 27 Octobre 2017 18:52:56
> > Objet: Re: [petsc-dev] SLEPc failure
> > I cannot load the files you sent. Please send the matrices in binary
> format.
> > The easiest way is to run your program with -eps_view_mat0
> binary:Atau.bin
> > -eps_view_mat1 binary:Btau.bin
> > However, the files are written at the end of EPSSolve() so if the solve
> fails
> > then it will not create the files. You can try running with -eps_max_it 1
> > or add code in your main program to write the matrices.
> > Jose
> > > El 27 oct 2017, a las 12:28, Franck Houssen <franck.houssen at inria.fr>
> > > escribió:
> > > Maybe could be convenient for the users to have an option (or an
> EPSSetXXX)
> > > to relax that check ?
> > > Data are attached.
> > > Franck
> > >> <petsc-dev at mcs.anl.gov>
> > >> Envoyé: Vendredi 27 Octobre 2017 10:15:44
> > >> There is no new option. What I mean is that from 3.7 to 3.8 we
> changed the
> > >> line that produces this error. But it seems that it is still failing
> in
> > >> your
> > >> problem. Maybe your B matrix is indefinite or not exactly symmetric.
> Can
> > >> you
> > >> send me the matrices?
> > >> Jose
> > >>> El 27 oct 2017, a las 9:57, Franck Houssen <franck.houssen at inria.fr>
> > >>> escribió:
> > >>> I use the development version (bitbucket clone). How to relax the
> check ?
> > >>> At command line option ?
> > >>> Franck
> > >>>> Envoyé: Jeudi 26 Octobre 2017 18:49:22
> > >>>>> El 26 oct 2017, a las 18:36, Franck Houssen <
> > >>>>> escribió:
> > >>>>> Here is a stack I end up with when trying to solve an eigen problem
> > >>>>> (real,
> > >>>>> sym, generalized) with SLEPc. My understanding is that, during the
> Gram
> > >>>>> Schmidt orthogonalisation, the projection of one basis vector
> turns out
> > >>>>> to
> > >>>>> be null.
> > >>>>> First, is this correct ? Second, in such cases, are there some
> > >>>>> recommended
> > >>>>> "recipe" to test/try (options) to get a clue on the problem ? (I
> would
> > >>>>> unfortunately perfectly understand the answer could be no !... As
> this
> > >>>>> totally depends on A/B).
> > >>>>> With arpack, the eigen problem is solved (so the matrix A and B I
> use
> > >>>>> seems
> > >>>>> to be relevant). But, when I change from arpack to
> > >>>>> krylovschur/ciss/arnoldi, I get the stack below.
> > >>>>> Franck
> > >>>>> [0]PETSC ERROR: #1 BV_SafeSqrt()
> > >>>>> [0]PETSC ERROR: #2 BVNorm_Private()
> > >>>>> [0]PETSC ERROR: #3 BVNormColumn()
> > >>>>> [0]PETSC ERROR: #4 BV_NormVecOrColumn()
> > >>>>> [0]PETSC ERROR: #5 BVOrthogonalizeCGS1()
> > >>>>> [0]PETSC ERROR: #6 BVOrthogonalizeGS()
> > >>>>> [0]PETSC ERROR: #7 BVOrthonormalizeColumn()
> > >>>>> [0]PETSC ERROR: #8 EPSFullLanczos()
> > >>>>> [0]PETSC ERROR: #9 EPSSolve_KrylovSchur_Symm()
> > >>>>> [0]PETSC ERROR: #10 EPSSolve()
> > >>>> Is this with SLEPc 3.8? In SLEPc 3.8 we relaxed this check so I
> would
> > >>>> suggest
> > >>>> trying with it.
> > >>>> Jose
> > > <ABtau.tar.gz>
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171028/7917187a/attachment.html>
