[petsc-dev] PetscSF in Fortran
Lawrence Mitchell wencel at gmail.com
Tue Oct 24 02:37:05 CDT 2017
> On 24 Oct 2017, at 06:21, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> - With PetscSFBcastBegin() / PetscSFBcastEnd() you currently still have to use the C MPI types in the Fortran calling code, rather than the Fortran ones. I think it is a bit confusing to have to mix the two up in the same code. If you put MPI_INTEGER instead of MPI_INT for example, it dies in F90Array1dAccess() with 'unsupported MPI_Datatype'. Could the Fortran MPI types be supported in these routines just by adding them as alternatives into the conditionals?
>>>  Hmm, Jed will need to provide wisdom the Linux manual page for MPI_INTEGER clearly states:
>>> Note that the Fortran types should only be used in Fortran programs, and the C types should only be used in C programs. For example, it is in error to use MPI_INT for a Fortran INTEGER. Datatypes are of type MPI_Datatype in C and of type INTEGER in Fortran.
>>>  If this is true then there is no place we can do the change properly.
>> Yes, I first thought that MPI_Type_f2c() would convert Fortran MPI datatypes to the C ones (e.g. turn MPI_INTEGER into MPI_INT), so that the C side of the interface wouldn't have to worry about the Fortran MPI datatypes, but it doesn't really seem to do that.
>  Do did I. Its existence seems to contradict the statement in the Linux manual page. Well wait for Jed.
A fortran INTEGER may have a different width to a C int.  Hence the distinction.  The MPI_XXX_f2c functions convert handles on the fortran side to handles on the C side (MPI_XXX_c2f does the opposite).  Perhaps the standard sheds some light:
Moving handles from Fortran to C
http://mpi-forum.org/docs/mpi-3.1/mpi31-report/node446.htm#Node446
Interlanguage communication
http://mpi-forum.org/docs/mpi-3.1/mpi31-report/node456.htm#Node456
Lawrence
