[petsc-dev] PetscSF in Fortran
    Adrian Croucher
    a.croucher at auckland.ac.nz
    Mon Oct 23 21:53:15 CDT 2017
hi
On 24/10/17 13:55, Adrian Croucher wrote:
> The stub for PetscSFSetGraph() is getting automatically generated (I
> can see it in /vec/f90-mod/ftn-auto-interfaces/petscpetscsf.h90), but
> the one for PetscSFGetGraph() is missing for some reason. Any clues?
Oh, I see, all it needs to turn on the auto stub is to remove the 'C' at
src/vec/is/sf/interface/sf.c:429.
However it looks like this auto stub for PetscSFGetGraph() can't return
pointers to the ilocal and iremote arrays, so you have to call it twice?
First to get the number of leaves (with null in the array parameters),
then allocate the arrays accordingly before calling PetscSFGetGraph()
again to fill them up?
If so it might be more convenient to have a custom binding that returned
pointer arrays, if possible, so you only had to call it once. That was
the kind of thing I did with my custom binding, but it was using integer
arrays rather than the PetscSFNode type.
I have a couple of other queries:
- you've allowed users to declare variables as being
'type(PetscSFNode)'. With most other PETSc Fortran types you can declare
variables as 'type(tXXX) :: foo' or 'XXX :: foo' (but not 'type(XXX) ::
foo'). Should this one perhaps be altered to work the same way, for
consistency?
- With PetscSFBcastBegin() / PetscSFBcastEnd() you currently still have
to use the C MPI types in the Fortran calling code, rather than the
Fortran ones. I think it is a bit confusing to have to mix the two up in
the same code. If you put MPI_INTEGER instead of MPI_INT for example, it
dies in F90Array1dAccess() with 'unsupported MPI_Datatype'. Could the
Fortran MPI types be supported in these routines just by adding them as
alternatives into the conditionals?
- Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
