[petsc-dev] [FORGED] Re: PetscSF in Fortran
Adrian Croucher a.croucher at auckland.ac.nz
Mon Oct 23 18:01:31 CDT 2017
hi Barry,
On 23/10/17 15:04, Barry Smith wrote:
>    Adrian,
>     Sorry for the delay in generating the bindings for you. I have put them in the branch
> barry/fortran-PetscSFBcastBegin
> the example src/vec/sf/examples/tutorials/ex1f.F90 attempts to test them. Please let us know if this works for you and if you need anything else. They will only work for MPIU_INT and MPIU_REAL and MPIU_SCALAR because that is the only Fortran pointer arrays we support currently.
Oh, thanks very much for that. I really only need support for integers
in my application at present, so what you've done should be fine for now.
I checked out your new branch but it is giving a bunch of warnings and
errors when I try to make it.
The warnings are:
In file included from
/home/acro018/software/PETSc/code/include/petscsys.h:1631:0,
                  from
/home/acro018/software/PETSc/code/include/petsc/private/petscimpl.h:8,
                  from
/home/acro018/software/PETSc/code/include/petsc/private/fortranimpl.h:6,
                  from
/home/acro018/software/PETSc/code/include/petsc/private/f90impl.h:4,
                  from
/home/acro018/software/PETSc/code/src/sys/f90-src/f90_cwrap.c:1:
/home/acro018/software/PETSc/code/src/sys/f90-src/f90_cwrap.c: In
function ‘F90Array1dCreate’:
/home/acro018/software/PETSc/code/src/sys/f90-src/f90_cwrap.c:60:80:
warning: cast from pointer to integer of different size
[-Wpointer-to-int-cast]
    } else SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_SUP,"unsupported
MPI_Datatype: %d",(PetscInt)type);
/home/acro018/software/PETSc/code/include/petscerror.h:126:122: note: in
definition of macro ‘SETERRQ1’
  #define SETERRQ1(comm,ierr,s,a1) return
PetscError(comm,__LINE__,PETSC_FUNCTION_NAME,__FILE__,ierr,PETSC_ERROR_INITIAL,s,a1)
function ‘F90Array1dAccess’:
/home/acro018/software/PETSc/code/src/sys/f90-src/f90_cwrap.c:78:80:
function ‘F90Array1dDestroy’:
/home/acro018/software/PETSc/code/src/sys/f90-src/f90_cwrap.c:93:80:
function ‘F90Array2dCreate’:
/home/acro018/software/PETSc/code/src/sys/f90-src/f90_cwrap.c:151:80:
function ‘F90Array2dAccess’:
/home/acro018/software/PETSc/code/src/sys/f90-src/f90_cwrap.c:166:80:
function ‘F90Array2dDestroy’:
/home/acro018/software/PETSc/code/src/sys/f90-src/f90_cwrap.c:181:80:
function ‘F90Array3dCreate’:
/home/acro018/software/PETSc/code/src/sys/f90-src/f90_cwrap.c:239:80:
function ‘F90Array3dAccess’:
/home/acro018/software/PETSc/code/src/sys/f90-src/f90_cwrap.c:254:80:
function ‘F90Array3dDestroy’:
/home/acro018/software/PETSc/code/src/sys/f90-src/f90_cwrap.c:269:80:
function ‘F90Array4dCreate’:
/home/acro018/software/PETSc/code/src/sys/f90-src/f90_cwrap.c:320:80:
function ‘F90Array4dAccess’:
/home/acro018/software/PETSc/code/src/sys/f90-src/f90_cwrap.c:335:80:
function ‘F90Array4dDestroy’:
/home/acro018/software/PETSc/code/src/sys/f90-src/f90_cwrap.c:344:80:
The errors look like they're from some unrelated DMPlex box mesh changes:
/home/acro018/software/PETSc/code/src/dm/impls/plex/ftn-auto/plexcreatef.c:
In function ‘dmplexcreateboxmesh_’:
/home/acro018/software/PETSc/code/src/dm/impls/plex/ftn-auto/plexcreatef.c:105:11:
error: incompatible type for argument 4 of ‘DMPlexCreateBoxMesh’
  *__ierr = DMPlexCreateBoxMesh(
/home/acro018/software/PETSc/code/src/dm/impls/plex/ftn-auto/plexcreatef.c:30:0:
/home/acro018/software/PETSc/code/include/petscdmplex.h:124:29: note:
expected ‘const PetscInt *’ but argument is of type ‘PetscBool’
  PETSC_EXTERN PetscErrorCode DMPlexCreateBoxMesh(MPI_Comm, PetscInt,
PetscBool, const PetscInt[], const PetscReal[], const PetscReal[], const
DMBoundaryType[], PetscBool, DM *);
/home/acro018/software/PETSc/code/src/dm/impls/plex/ftn-auto/plexcreatef.c:106:52:
warning: passing argument 5 of ‘DMPlexCreateBoxMesh’ from incompatible
pointer type
   MPI_Comm_f2c(*(comm)),*dim,*numFaces,*interpolate,dm);
expected ‘const PetscReal *’ but argument is of type ‘struct _p_DM **’
error: too few arguments to function ‘DMPlexCreateBoxMesh’
declared here
In function ‘dmplexcreatehexboxmesh_’:
/home/acro018/software/PETSc/code/src/dm/impls/plex/ftn-auto/plexcreatef.c:109:1:
warning: implicit declaration of function ‘DMPlexCreateHexBoxMesh’
[-Wimplicit-function-declaration]
  *__ierr = DMPlexCreateHexBoxMesh(
gmakefile:227: recipe for target
'linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexcreatef.o' failed
make[2]: ***
[linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexcreatef.o] Error 1
> I was shocked, shocked to discover that it looks like PetscSF has essentially no bindings for Fortran. We can add more relatively easily if you need them. I don't understand how you could previously test your code given that PetscSFCreate() didn't even have a Fortran stub generated?
My tests are based on DMPlex and I was just using DMGetPointSF() and
DMPlexDistribute() to get some SFs to test.
I have also written some Fortran bindings for PetscSFGetGraph() and
PetscSFSetGraph(). However it looks like you have made the PetscSFNode
type accessible from Fortran in your branch? In which case my bindings
could probably be modified to make use of that. Currently they look like
this (using a 2-by-n array of int instead of an array of PetscSFNode for
the root data array):
+      Interface
+         Subroutine PetscSFGetGraph(sf,nroots,nleaves,
+     &      larray,rarray,ierr)
+          use petscisdef
+          PetscSF :: sf
+          PetscInt :: nroots, nleaves
+          PetscInt, pointer :: larray(:)
+          PetscInt, pointer :: rarray(:,:)
+          PetscErrorCode :: ierr
+        End Subroutine
+      End Interface
+PETSC_EXTERN void PETSC_STDCALL petscsfgetgraph_(PetscSF *sf, PetscInt
*nroots, PetscInt *nleaves, F90Array1d *lptr, F90Array2d *rptr, int
*ierr PETSC_F90_2PTR_PROTO(lptrd) PETSC_F90_2PTR_PROTO(rptrd))
+  const PetscInt *ilocal;
+  const PetscSFNode *iremote;
+  *ierr = PetscSFGetGraph(*sf, nroots, nleaves, &ilocal, &iremote); if
(*ierr) return;
+  *ierr = F90Array1dCreate((void*) ilocal, PETSC_INT, 1, *nleaves, lptr
PETSC_F90_2PTR_PARAM(lptrd)); if (*ierr) return;
+  *ierr = F90Array2dCreate((void*) iremote, PETSC_INT, 1, 2, 1,
*nleaves, rptr PETSC_F90_2PTR_PARAM(rptrd));
- Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
