[petsc-dev] TS Terminology
Matthew Knepley
knepley at gmail.com
Sat Oct 21 07:30:02 CDT 2017
On Fri, Oct 20, 2017 at 4:21 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> >> Note that TSComputeIFunction is very much like SNESComputeFunction,
> >> which includes
> >> if (snes->vec_rhs) {
> >> ierr = VecAXPY(y,-1.0,snes->vec_rhs);CHKERRQ(ierr);
> >> Why haven't you complained about that?
> > Good point. I did not notice. This came up because the initialization
> > of input vectors is inconsistent between TSComputeIFunction() and
> > TSComputeIFunctionLocal(). The former does not zero the output vec,
> > but the later does.
> The latter function doesn't exist so maybe you mean
> TSComputeIFunction_DMDA with ADD_VALUES? That's because the DMDA needs
> it when using ADD_VALUES, just like SNESComputeFunction_DMDA. When
> using INSERT_VALUES, the user is responsible for setting every entry.
> Is any of this different from SNES?
No I mean TSComputeIFunction_DMLocal(). So if you use DMTSSetIFunction()
you get
different initialization behavior than if you use DMTSSetIFunctionLocal().
This is what Brad
was complaining about originally.
Matt
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171021/5f8afa7d/attachment.html>
