[petsc-dev] TS Terminology
Fri Oct 20 17:37:47 CDT 2017
On Fri, Oct 20, 2017 at 6:36 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > I think you are right that the SNES thing needs fixed as well. The
> > problem has not come up because no one ever uses that interface. It is
> > only there because it makes FAS a lot easier.
> That interface precedes FAS.  It's there because it's convenient.
That is not my memory.
  Matt
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171020/7b108271/attachment-0001.html>
