[petsc-dev] MatAssembly and VecAssembly
Barry Smith
bsmith at mcs.anl.gov
Fri Oct 20 17:24:21 CDT 2017
> On Oct 20, 2017, at 12:17 PM, Kong, Fande <fande.kong at inl.gov> wrote:
> How about to do a global check (MPI_Allreduce)?
Kill you for large number of processes.
> If we do not set values at all and the matrix is already assembled, we just return without doing anything?
> How expensive, in the current implementation, to call MatAssemblyBegin/End if there are no any stashed data? Is it so cheap that we can just ignore it?
It requires at least one global reduction.
> I am asking because we call MatAssemblyBegin/End so often in MOOSE. I want to make sure this is not going to bring up any performance issue.
You need to check each use in MOOSE and see WHY it is being called. If no reason then don't call.
Barry
> Fande,
> On Fri, Oct 20, 2017 at 11:08 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> One process sets a value in the matrix, the others do not. They all call MatAssemblyBegin(). Some processes will skip the assembly and hence the code will hang.
> > On Oct 20, 2017, at 12:03 PM, Kong, Fande <fande.kong at inl.gov> wrote:
> > Hi All,
> > In Mat/VecAssemblyBegin/End, why we do not check if or not mat/vec is assembled. If mat/vec is already assembled, should we just return without doing anything?
> > I think we have some particular reasons not to check if the matrix is assembled. I honestly do not know why.
> > Thanks,
> > Fande,
