[petsc-dev] TS Terminology
Jed Brown jed at jedbrown.org
Fri Oct 20 17:24:11 CDT 2017
"Zhang, Hong" <hongzhang at anl.gov> writes:
>>> Another confusion which is not related to this topic is the usage of the word "DAE".
>>> I disagree with the statement "In general, this (the general form) is a differential algebraic equation (DAE)" on page 141 of the manual.
>>> The word "DAE" has been abused in the comments of many TS functions (including TSComputeIFunction), where it actually should mean "DAE or ODE".
>>> PETSc uses the same interfaces for both DAE and ODE, but it is wrong to consider ODE as a special case of DAE.
>>> They are fundamentally different from each other and should be distinguished explicitly in the manual and the source code.
>> Is this not valid usage?
>>  "Thus, ODEs have index 0."
> One can think of scalar as 0d matrix. But how often do people use 0d matrix for scalar?
The elegance of differential geometry would be lost if scalars were not
0-forms.
> When people say DAE, naturally it refers to DAE with index 1 or higher (ODE+algebraic constraints).
> If PETSc TS developers are really DAE zealots, at least it should be specified that their "DAE" includes index 0 DAE.
I'm fine with explicitly stating that ODE are index 0 DAE and having
phrases like "if your DAE is an ODE, the explicit interface can be
used".
