[petsc-dev] MatAssembly and VecAssembly
Kong, Fande fande.kong at inl.gov
Fri Oct 20 12:17:47 CDT 2017
How about to do  a global check (MPI_Allreduce)? If we do not set values at
all and the matrix is already assembled, we just return without doing
anything?
How expensive, in the current implementation,  to call MatAssemblyBegin/End
if there are no any stashed data? Is it so cheap that we can just ignore
it?
I am asking because we call MatAssemblyBegin/End so often in MOOSE. I want
to make sure this is not going to bring up any performance issue.
Fande,
On Fri, Oct 20, 2017 at 11:08 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   One process sets a value in the matrix, the others do not. They all call
> MatAssemblyBegin(). Some processes will skip the assembly and hence the
> code will hang.
> > On Oct 20, 2017, at 12:03 PM, Kong, Fande <fande.kong at inl.gov> wrote:
> > Hi All,
> > In Mat/VecAssemblyBegin/End, why we do not check if or not mat/vec is
> assembled. If mat/vec is already assembled, should we just return without
> doing anything?
> > I think we have some particular reasons not to check if the matrix is
> assembled. I honestly do not know why.
> > Thanks,
> > Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171020/dcf1246c/attachment-0001.html>
